R56 Strong Draft in driver's footwell
Old Oct 22, 2017 | 08:00 PM
FlyPenFly's Avatar
FlyPenFly
Might be in passenger too but not sure.
Anyway at highway speeds, I can feel a strong draft coming down from near the ODB port area but more central.
Any ideas? I'm guessing previous owner removed a panel somewhere and never replaced it. AC on or off makes no difference.
Old Oct 23, 2017 | 01:29 AM
Shotgun_banjo's Avatar
Shotgun_banjo
Maybe you have a busted blend door actuator.
Old Oct 23, 2017 | 06:31 AM
FlyPenFly's Avatar
FlyPenFly
Maybe but the draft is definitely speed dependent. The normal vent AC and heater work fine.
Old Oct 23, 2017 | 06:59 AM
MiniToBe's Avatar
MiniToBe
did you check the cable bundle plug that goes through the firewall? also check the door weather seal strip
Old Oct 23, 2017 | 10:50 AM
FlyPenFly's Avatar
FlyPenFly
Will check for the cable bundle plug...
I wouldn't think it's the door strip because it's not coming from the side, it's coming from directly in the center area
