i just installed Kensun HID kit. the light works properly but after i i startup my car HID headlight both side start flickering all the time. anyone knows how to solve the problems?
Daytime running light is one of the options in the menus in the dashboard. Look in your Owners Manual. If it's already turned off, it was the only thing I could think of.
Thanks so much. It already turned off. Some people say that i need to get "HID kit Computer Warning Canceller & Anti Flicker" im not sure how it works.
Yes. The MINI sends voltage through the bulbs at regular intervals to make sure the bulbs work. That voltage is enough to flash the LED as LED takes so little juice. The fix was to program the car not to check that set of bulbs. The Carly app will allow you to configure that. I forget what exact bulbs were selected in the app. You can select all sorts of lights like side marker ones,etc. But that is your problem.
