R56 Please help, rear camber on '08 r56s
Old Jun 18, 2017 | 05:01 PM
Ethan Cohen's Avatar
Ethan Cohen
I need help on figuring out the camber issue on my 08 r56. The rear left wheel had a significant amount of negative camber compared to the rear right wheel. I took the wheel off and adjusted the camber via the adjustable control arm. It was even with the rear right wheel for about a day of light driving then it went back to how it was before I adjusted it. I checked to see if the 12 point bolt on the lower control arm was loose and t wasn't. The control arm isn't bent or anything, it all looks normal. Is there something I can do to fix this issue? Thanks
Old Jun 19, 2017 | 08:44 AM
Check the rear upper shock mounts and also check the rear springs for sagging or a broken spring.
Rear upper shock mounts and smooshing of the stock foam.
https://www.northamericanmotoring.co...ts-of-toe.html
Old Jun 19, 2017 | 12:06 PM
Ethan Cohen
Thanks for the reply, I'll check it out when I can. I'm at work right now but after I look at it I'll post back and let you know
Old Jun 22, 2017 | 10:17 AM
Ok, you are welcome.
Old Jul 4, 2017 | 01:07 PM
miniuy's Avatar
miniuy
Ethan,
any update on this?
