R56 Thermostat Housing Out!! Need help
Old Apr 9, 2017 | 01:24 PM
Colorado56's Avatar
Colorado56
So my thermostat housing went out the other day and I bought a replacement part but it won't fit!!
The bleeder valve and the temp sensor seem to get in the way of the fuel pump!!
I don't know what to do next. Has anyone run into these problems!??
Old Apr 9, 2017 | 01:31 PM
yesti's Avatar
yesti
You got the wrong version. Thermostats had multiple revisions. Check the picture before purchasing to make sure it will fit. I made the same mistake. Be sure to get the right wiring harness for the two sensors too
Old Apr 9, 2017 | 02:35 PM
BigBoost's Avatar
BigBoost
Wrong one take it back
or send it back
Old Apr 9, 2017 | 03:09 PM
Colorado56's Avatar
Colorado56
So then it's going to be this new version with the sensor facing at an angle right?
Old Apr 10, 2017 | 05:01 AM
MiniToBe's Avatar
MiniToBe
This housing is for the N18 engine (2011-2015). This should be the correct one. you will also need the adapter for the sensors since the original wiring has only one 4pin plug.
