R56 Parking brake button pushed inside?
Old Jan 13, 2016 | 08:04 AM
clearwaterblue's Avatar
clearwaterblue
I have a strange problem. I cleaned my R56 a couple days ago and pulled up the parking brake to clean underneath it. I left the brake lever up when I was done. My wife got in the car later and lowered the parking brake. When she pressed the button in to lower the lever, the button wen't inside the black casing and didn't come back out. That's the way she described it, but I actually thing the black casing may have came out and covered the silver button.
I can still open and close the lever, but I must poke my finger into the black casing and push the button. It's in there pretty far (maybe three inches back).
I tried sliding the casing back, but it doesn't budge. Anyone had this problem before? Any idea what happened here?
Old Jan 13, 2016 | 08:20 AM
TWISTER's Avatar
TWISTER
Try taking the handle off to inspect it further. http://www.robincasady.com/ShiftKnob...ons/Index.html
Old Jan 13, 2016 | 08:28 AM
clearwaterblue
Thanks for the link. I'll try it and see what I can find.
Old Jan 13, 2016 | 08:52 AM
Slide the handle off a bit and inspect, the handle also might not be all the way back.
Old Jan 13, 2016 | 10:33 AM
dongood's Avatar
dongood
Mine did that to, and perhaps for the same reasons.
For whatever reason I had really pulled the lever up; way past what was needed to lock the brakes.
Then when the wife tried to drive the car she had to use 2 hands to release the brake. She drove the car and reported the same issue when she went to use the parking brake. I suspect her 2 hand method slid the grip towards the end of the lever.
I simply pushed the grip back to it's original position and made a mental note to not do that again.
No problems since.
Old Jan 13, 2016 | 10:36 AM
clearwaterblue
Good to know I'm not the only one. .
I'll have some time to check it later when I'm done working.
Old Jan 17, 2016 | 08:43 AM
ridinDirty's Avatar
ridinDirty
There are a lot of plastic parts inside , plastic collar, plastic push rod that has an offset in it with the spring. Something might have broke or slipped.
I bought a complete ebrake on feeBay for 45 bucks.
I chopped it up for some custom work so I saw how it worked. I still have some of the inside parts if you need them .
JamesDeBart
Feb 10, 2016 07:13 AM
eurojcw
Dec 3, 2015 01:03 AM
PelicanParts.com
Nov 30, 2015 12:20 PM
socalr53
Nov 29, 2015 11:09 PM
PelicanParts.com
Accessory Products
Nov 25, 2015 02:05 PM
