R56 How To Install BSH OCC on 2009 R56 With Optional Hood Latch Sensor?
Old Jun 30, 2015 | 09:02 PM
newmail445's Avatar
newmail445
Hi, so the BSH OCC mounts on a tab that -should- be free. It's located to the right of the air filter housing. However my car has the optional security system and the hood latch sensor now takes up that tab. I know there's a second install spot that would require me to delete the fresh air tube, but I do not want to do that. So, how should I go about installing the OCC?
TIA
Link to where it -should- install (to the right of the air filter housing): http://farm1.static.flickr.com/128/3...4b549bc2_b.jpg
Link showing BSH OCC installed: http://img99.imageshack.us/img99/1245/bsh5.jpg
Link to tab taken by Hood latch sensor: *ignore the yellow drawings* the Hood latch sensor is at the top near the air filter box
https://cimg5.ibsrv.net/gimg/www.nor...92386007ed.jpg
Old Jun 30, 2015 | 10:00 PM
Indimanic's Avatar
Indimanic
Just move the switch to another location
Here what I did with 2 cans.
Most guys prefer 2 cans if u know what I mean.
Attached Thumbnails How To Install BSH OCC on 2009 R56 With Optional Hood Latch Sensor?-occ-image.jpg
Old Jun 30, 2015 | 10:28 PM
newmail445's Avatar
newmail445
Wow, great looking engine bay! Forgive my ignorance as I'm still new to cars.
1. Where did you put the hood latch sensor and how did you secure it?
2. I know one OCC attaches to the valve cover and turbo inlet. Where does the other one attach?
Old Jul 1, 2015 | 06:07 AM
Indimanic's Avatar
Indimanic
I did not have the switch but just make a small bracket and move it.
The OCC are run serially in line with 2 ball valves and a bunch of plumbing so I can separately control how much vacuum and draw from either outlet/inlet or close them entirely and vent to atmosphere on track days. The 2nd can never has anything in it. The bad news is that even with the OCC you will still get carbon build up as there is always some oil vapor in the intake. I checked after 6k miles and some evidence of carbon was on the valves. Good news is that sea foam run into the manifold took care of it.
Sexual Chocolate
Mar 31, 2019 08:02 PM
marendt428
Nov 14, 2015 10:03 AM
marendt428
Aug 8, 2015 04:44 AM
