R56 Questions over DSC/DTC, E-Diff, ABS
Old May 12, 2015 | 08:58 AM
dawgscj7's Avatar
dawgscj7
Hello there,
I have a 2010 JCW. I havent had the car too long now but I have questions pertaining to using the car as intended, as the bad little hot hatch that it is. Im a national level autocrosser and I moved to this car this spring, its totally prepped for STX. I'm turning off DSC and DTC every time by holding the button down for 5 seconds.
Here is the real question: Why is something intervening occasionally? It feels like traction control. I was powering out of a corner, carrying into the next and lightly lifted to rotate and stood back on the power. The car turned in nicely and I started to roll back on the throttle and lost a little bit of traction from the suspension load up and counter steered and throttled out but then BAM! Something kicked in and pulled all available power for a moment and sent me into a spin. Ive buried both feet and safely stopped the car. What caused that if everything was turned off? I never had that issue in my SMF R53.
Ive tried to duplicate the scenario in a safer way and its happening consistently. I also hve noticed that it will happen going up steep grades amidst acceleration and sudden traction loss and then BAM! It does it again. Its very frustrating and I have both turned off to the extent of my knowledge. Also could I pull the fuses for DSC/DTC, Dynamic Braking, etc?
Also does anyone have specs, info, knowledge of the factory electronic differential? Any would be great.
Discuss
Thanks,
Rob
Old May 13, 2015 | 10:22 AM
dawgscj7's Avatar
dawgscj7
Bump someone knows something
Old May 13, 2015 | 03:22 PM
hsautocrosser's Avatar
hsautocrosser
There are several threads on this. The most relevant is:
https://www.northamericanmotoring.co...any-ideas.html
Old May 13, 2015 | 04:19 PM
dawgscj7's Avatar
dawgscj7
Well I guess I'll try pulling the fuse. It sounds like im fighting the ELSD
Old May 13, 2015 | 04:32 PM
hsautocrosser
ELSD applies brakes to one front wheel if it is spinning faster than the other one. It does not cut power. DSC turns itself back on and cuts power. I haven't yet seen any results either way from pulling fuses.
Old May 13, 2015 | 04:34 PM
dawgscj7's Avatar
dawgscj7
Damn. Well has anyone shown that the DCS wont intervene after getting an aftermarket mechanical differential?
Old May 13, 2015 | 09:08 PM
hsautocrosser
V10climber would be a good person to ask.
donniedarko
Oct 21, 2015 01:15 PM
Sep 4, 2015 09:23 AM
Ntety
Sep 2, 2015 08:39 PM
