R56 Loose part found in oil pan, need help identifying it
Old Dec 21, 2016 | 07:12 AM
  #26
herbie_53_guy's Avatar
herbie_53_guy
confirmed today, its the pins for the 2 halves of the motor. the pins measure 8x17mm which is exactly the same as #8 in the diagram. This car over heated in the past and the case expanded and these must have slip out and fallen into the pan.
Old Feb 13, 2017 | 06:56 AM
  #27
DBB888's Avatar
DBB888
Are you sure thats a dowel pin? Why would there be a hole in the middle?
We have a car in the shop with that pin found and it looks like a oil restrictor
We have a codes for vanos inlet adaption stop and Vanos inlet actuator movement.
Both codes are either bad oil/ bad vanos solenoids/ or timing chain kit
We replaced oil - then solenoids- then timing chain kit with new cam gears
and still have this code after- we found this pin in the pan along with tons of broken plastic pieced from the guides.
Old Feb 13, 2017 | 12:25 PM
  #28
DBB888's Avatar
DBB888
Ordered all the dowels including # 8 and its solid-They are all solid does not have a hole going through it
Any other ideas??
Old Oct 12, 2020 | 06:07 PM
  #29
Hayden Jones's Avatar
Hayden Jones
Did you ever identify pin. I just found one in 2008 mini clubman after replacing timing chain and pulling oil pan to remove plastic peices that broke off guide. Car runs good, no codes or misfires and timing stable and advances as should with increasing RPMs per obd scanner live data view. Don't know history on car prior to 102,000 miles but it did overheat right before doing timing chain. I just did timing chain at same time I replaced leaking water pump as a preventative measure since I had car apart and their history with failures.
Old Nov 15, 2020 | 06:54 PM
  #30
Charles Christensen's Avatar
Charles Christensen
looks like part of a timing chain guide or the pivoting point of guide
Old Jul 22, 2023 | 02:58 PM
  #31
Mike_R's Avatar
Mike_R
Ok, I'm hopefully bumping this thread. I had this exact same pin fall off the top of my oil pump when I removed it today (2009, R56, Base cooper w/ N12). I found this thread with great joy but as I read I got sad. There's no consensus what it is!
  • I've got my head off so I examined the old timing chain guides and see no place for a pin like this. The pivot point on those things is a pretty large plastic snap together circle and not a small hole pinned by a steel peg
  • Furthermore I have a brand new, unopened timing chain set and there is no sign of a pin like this.
  • I correctly removed the valvetronic servo by backing the allen key out and that work was done on a workbench any way and not over the engine block; so I don't think its that
  • The old timing chain is in fine shape and definitely not missing a pin, so I don't think its that
  • I really don't think its a guide pin from the engine block. I do believe this engine over heated, but I just can't imagine it opened itself that wide without something else terrible happening. Besides the block pins do not have the machined hole as previous posters noted.
  • I pulled the car in to its current location myself; definitely no loud bangs or thunks to indicate a busted piston/rod
  • The alignment dowels for the head to engine block are spring dowels and do not resemble the piece.
I wrote all that because those seem like the prevailing theories in the thread. I really hoped it was the timing guide, but alas.
This engine DID have its freeze/expansion cap blow off (with the resulting oil/coolant sludge.. what a mess) so I was hoping it was related to that, but it does not seem so.
I'm adding pics of the part here.
If ANYONE has any new info I'd sure like to hear it!
I'll be taking it to the automotive machinist who is checking my head and I'll let you know if we come up with anything
Mike
Old Sep 7, 2025 | 10:03 PM
  #32
Odoul1's Avatar
Odoul1
This was inside my oil pan. Found it duran routine oil change and noticed draining oil was blocked..investigated and removed oil pan and this was what i found...what is and where did it come from..car is a 2013 mini cooper base auto non turbo...
Originally Posted by Miguel A.
Hello, Im new to the forum not sure if this is the right place to post it.
Anyway, long story short I recently embarked on a journey to replace a burnt head gasket on a 2008 Mini Cooper Base. so far so good, found that there are a couple of burnt valves and I am taking the head to a shop. I took the oil pan off this morning and found a piece of metal in the sludge. Does anybody know where it is from? I can't seem to find where it came from here is a picture, thanks everyone in advanced for any info!
TBRoye
Feb 14, 2021 05:16 AM
bobbiemartin
Jan 20, 2016 05:28 PM
Etrain
11
Aug 20, 2015 10:22 AM
PSIChocolate
Aug 13, 2015 12:46 PM
minipopkart
Aug 13, 2015 05:22 AM
