R56 R56 Compression Issues
Old Dec 31, 2014 | 08:10 PM
nadams93's Avatar
nadams93
I bought a 2007 base Mini with what I was told was a blown head gasket. It ended up having bad rings also. I honed the cylinders, replaced the rings and replaced the head gaskets and still have low compression in cylinder #3 (~60psi). I am not sure where else to go with this vehicle whether its a cracked head, leaking valves or even a cracked block, which I can't imagine with steel liners. Any tips or information would be appreciated.
Thanks!
Old Jan 1, 2015 | 09:22 AM
AZdsrt's Avatar
AZdsrt
Most likely a valve. Do a leak down test. Too bad you didn't have the head checked when you had it apart.
Old Jan 2, 2015 | 06:42 AM
v10climber's Avatar
v10climber
You should have had the head checked over at a machine shop to make sure it wasn't cracked and/or warped.
Old Jan 2, 2015 | 05:35 PM
nadams93's Avatar
nadams93
I had the head machined so I'm not worried about it being warped. After tearing this engine apart four times, I'm finally cutting my losses and parting out the car.
W0TM8
Dec 19, 2019 07:50 AM
kpl
Aug 11, 2015 04:52 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
