R56 r56 mini cooper trailing arm stripped
Old Dec 28, 2014 | 05:13 PM
07MiniCopperS's Avatar
07MiniCopperS
I have a 2007 mini cooper s and was replacing struts this weekend on all four corners. I noticed when pulling out the bolt on the aluminum passenger side trailing arm that the hole was stripped pretty badly when I pulled that trilobe bolt out. I would have to guess it was from the previous owner when he put the lowering springs in as the struts had never been replaced in 100k miles. I have had the idea of putting a helicoil in the hole but would require two helicoils using the longest length of helicoils for 14mm. Option two is to make a stud that is permanently in the arm and is stepped down to accept the strut and hold it on with a nut. The 3rd option is to just replace the trailing arm. Any other ideas or experience with this?
Old Dec 29, 2014 | 05:04 AM
richardsperry's Avatar
richardsperry
Timesert, or helicoil will both work.
But I would use a thread chaser first to see if the threads can be saved. (not a tap, a thread chaser)
Either are a lot cheaper than a new $500 trailing arm...
Old Dec 29, 2014 | 05:16 AM
v10climber's Avatar
v10climber
Just toss a helicoil in there. It's a very common issue with these cars. I've had the rear struts out 6-7 times since helicoiling both sides. The drivers side helicoil backed out once when I was removing the bolt but I chased the threads with the tap and threaded in a new helicoil. No issues even auto-xing hard on 235/40/17 r-compound tires.
wkp1219
Nov 13, 2015 07:52 AM
xpunisherx
Aug 10, 2015 10:50 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
