R56 Picking up 2009 R56 MCS on Monday
I may be picking up a 2009 R56 MCS automatic with 63k miles. I am buying from the original owner that has maintenance records from the dealership since brand new.
I've noticed that some of the issues were carbon build up, water pump and timing chains being known issues. Here are some maintenance that had been done
- Earlier this year, the timing chain made a noise at start up. The dealership replaced seal rings and replaced timing chain. (QUESTION, HOW OFTEN DOES THE TIMING CHAIN NEED TO BE REPLACED?)
- New Turbo heat shields
- Replaced Aux water pump in 2012
- All brakes had been replaced in 2011
- Removed intake manifold and found carbon levels between intake valves. Performed carbon cleaning on valves. Added 1 bottle of in tank fuel additive in 2011.
- Misc rattles, oil change services.
After these maintenance had been done, should I still be worried about the known issues? How often do you have to do a carbon clean up and replacement of the timing chains? Any idea of costs?
Are there any other known issues that I should be aware of?
Timing chain life is all over the board, so really no way to predict what life you will get out of it.
For the carbon cleaning, I'd probably assume every 50k miles, but that could vary quite a bit as well.
BTW, it's a very good thing that the PO had taken care of timing chain. Otherwise this would have been a $1.8K bill in your near future!
The cost for walnut shell blasting the intake valves ranges from $100 in parts to DIY, $350 at an independent, or $600 at a dealer.
[QUOTE=mikehsu;4026174Are there any other known issues that I should be aware of?[/QUOTE]
This covers most of them.
You may eventually be looking at:
- few minor oil leaks (valve cover gasket, oil filter housing, etc - nothing tragic).
- major oil leak will eventually develop at the point where oil cooling lines connects to the turbo. About $80 in parts to DIY replace; add ~7 hours of labor if you pay someone to do it for you.
- water pump and thermostat will eventually need to be replaced as they leak, or pro-actively
The usual maintenance will also need to be done, as with all cars:
- brake pads and rotors (as needed)
- tires (as needed, consider ditching RFT tires if still on the car)
- oil and filter changes (as needed, or every 8K miles)
- brake fluid and coolant changes (as needed, or every 2 years)
Lastly, have you considered taking the car to a competent shop for a pre-purchase inspection? I always do it when buying used cars, and they always find something that justifies negotiating the purchase price down by more than what you paid for the inspection. Please you get a piece of mind having had the car inspected by another set of competent eyes and hands.
a
marendt428
Nov 14, 2015 10:03 AM
