R56 Turn Signal/Tail Light/Brake Light Problem
Old Oct 6, 2014 | 11:21 AM
Warthog1956's Avatar
Warthog1956
I've got a 2007 S. The problem started with the bulb out indicator coming on when I started the car. The driver's side rear light unit (turn signal/tail light/brake light) was not functioning. When I would turn the left turn signal on, I would get a few signal out rapid blinks, then the whole unit would function as designed. The light unit started going out periodically while I was driving. Every time I turned the car off and restarted it and turned the left signal on the unit would start working. It started going out more often and now the light unit doesn't function and won't reset. Any ideas where to even start looking for the problem?
Old Oct 6, 2014 | 11:35 AM
Grizld700's Avatar
Grizld700
Have you already tried replacing said bulb?
Old Oct 6, 2014 | 11:38 AM
Warthog1956
Hi Grizld700. I replaced all three bulbs, even though they worked when I would 'reset' the unit by turning the left turn signal on.
Old Oct 6, 2014 | 12:45 PM
Grizld700's Avatar
Grizld700
Hmmmm. Where to start? Well I would check the connectors themselves. Make sure there is no corrosion, or melted components from faulty bulbs. If nothing is obvious from there, could be wiring issue, might have a wire shorting out. Then after that I suppose it could be the multifunction switch too.
Does the front turn signal continue to work as well?
And that would be the extent of my knowledge. Good luck and I hope you get it sorted!
Teh
Jun 13, 2018 02:59 PM
Dec 23, 2015 10:36 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
