R56 Removing shift boy?
Old Feb 28, 2014 | 12:18 PM
RicWRX's Avatar
RicWRX
Removing shift boy?
I want install a new shift, but the ring holding on the **** will not come off. Does it need to be cut off?
Old Feb 28, 2014 | 01:55 PM
v10climber's Avatar
v10climber
The shift **** just presses on. Pull up really hard. Try not to hit yourself in the face
Sent from my DROID RAZR HD using NAMotoring
Old Feb 28, 2014 | 02:32 PM
RicWRX's Avatar
RicWRX
I got **** off ok, I finally cut the band holding the boot to the ****. I was able to install the new boot. Sorry about the misspelling, my IPad automatically spells sometimes and I didn't catch it.
Old Feb 28, 2014 | 02:56 PM
cranker625's Avatar
cranker625
I hope you didn't cut the collar that holds the top of the boot to the bottom of the shifter.
Because without the collar (overtime) the shift boot will become "saggy".
It will slowly sit lower and lower until your shifter is exposed. Which is as ugly as it gets.
The entire shifter assembly in the cabin can be removed without any tools.
1. The shift **** pulls upwards, just watch out not to hit your face.
2. The bottom of the shift **** has a knotch the holds onto the shift boot collar.
3. The bottom of the shift boot is clipped onto the center console with a trim ring.
4. The top of the shift boot is connected to the **** with a plastic collar.
Getrieben
Sep 12, 2024 07:03 AM
cawwwtun
May 3, 2016 08:03 AM
AdrenaliNate
Nov 4, 2015 07:26 PM
greekzilla
Aug 23, 2015 03:44 PM
