R56 What is wrong with MINI?
Old Dec 5, 2013 | 10:19 PM
  #51
Systemlord's Avatar
Systemlord
Originally Posted by MiniCruise
I'm assuming that it does but don't know for sure. I bought the upgraded tensioner and my first plan is to replace that. As you probably know, you can tell by sound if there is something wrong. My car has low miles so if it sounds tight on a cold day after swapping out the tensioner I will be confident in it for now. The nearest dealer is a few hours away so that isn't a good option for me. If I knew for sure they would replace all hardware I might go that route but many say that the dealers aren't fixing their problem and since I don't have a dealer locally I will just deal with it myself for now.
I have had some bad luck with vehicles. Years ago I had a '90 Toyota 4wd with the 22RE engine. It was supposed to be a 300k engine. When I hit 116k, the timing chain jumped and it destroyed all the intake valves. Come to find out, they changed the timing chain setup in the late 80's... To a plastic guide and spring loaded tensioner system..... Just like the Mini! It failed but lasted much longer than the mini. Same basic problem though. I pulled the head and oil pan and fixed it. Then I had a Suzuki 2004 GSXR 600 sport bike. They are supposed to be bulletproof also. I was cruising in traffic one day at about 50 mph. I downshifted and the engine took a complete dump and threw a rod threw the front of the motor. It only had 6600 miles on it and was not ridden very hard. Such is life I guess. **** happens, just tired of it happening to me. I take care of my stuff.
My brother-in-law has the same motor (88 though), he replaced guide with a metal one because the plastic one broke twice. He's got 388k miles on it, it's probably worth a few hundred dollars!
Old Dec 6, 2013 | 04:18 AM
  #52
MiniCruise's Avatar
MiniCruise
Originally Posted by vetsvette
It's a 150 mile round trip for me to my closest dealer, but if there was a chance of them replacing the Cam Chain Cassette on their dime I would drive a lot farther. I took my car in for the heat shield and cam chain recall. They installed the heat shield, but did not do the cam chain because the parts were not in stock. They are rescheduling me for next week and supplying me with a loaner. All they did was look at the tensioner, and since it was the original one, they said they would just replace the whole thing. If they see a new style tensioner, they will stop right there because the bulletin tells them to. Replacing the tensioner yourself could end up costing you a couple grand down the road. Another problem with replacing that part yourself is the chain itself may have already been stretched out of tolerance and a new tensioner will not fix that.
I'm pretty sure the tensioner will fix it. The motor is quiet when warm. If the problem persists and the chain an d guides need replaced, I will do that work myself also. The parts are about 400 and I can probably do it in less time than it would take to drive to the dealer and back.
Old Dec 11, 2013 | 03:52 PM
  #53
GorillaArms's Avatar
GorillaArms
My R56 is a complete piece of garbage. I bought it used with ~45k miles. I now have ~73k on the odo and its been nothing but trouble. Its very sad that the quality is so poor. The car is quite fun to drive when its running correctly. I take very good car of my cars. I have an 03' Ford Excursion with ~175k miles and an 88' Porsche with ~150k miles. Never again will I purchase a Mini product.
Old Dec 11, 2013 | 05:01 PM
  #54
richardsperry's Avatar
richardsperry
I don't know, 4 years, 40k+ miles, no real issues except squeaks... The timing chain and tensioner were replaced while it was in for factory maintenance...other than that, it's a great car.
Old Dec 13, 2013 | 12:41 PM
  #55
MiniCruise's Avatar
MiniCruise
I swapped out my timing chain tensioner today for the upgraded (same length) version. Although it wasn't a 20 minute job for me, it wasn't difficult. The only problem I ran into was removing the hoses that needed to be removed, largely because it was only about 40 degrees in my garage.
I am very glad that I went ahead and did this. When I removed the original tensioner, it was barely hand tight. I don't know the history of my car (I purchased it with 24k miles on it) but the tensioner looks to be the original one and I doubt anyone else had been in there. I was shocked at how loose it was. I had a long 1/2" drive ratchet and prepared to put some muscle into loosening it but I barely put any pressure on it before it started turning. I think I dodged a bullet here. The new one is torqued to 65nm.
The plunger on the new tensioner is much stiffer as others have noted, and the car immediately sounded better as soon as I fired it up. Hopefully this solves the problem for at least a few years since I will probably only put 10K - 12k miles per year on it.
Old Dec 13, 2013 | 03:48 PM
  #56
DneprDave's Avatar
DneprDave
There was a problem with tensioners not being torqued properly at the factory sometime in 2009 or 2010.
Maybe your car was one of those.
Dave
Old Dec 22, 2013 | 06:18 PM
  #57
komet155's Avatar
komet155
I probably would have had second thoughts if I had read as many horror stories as I've had since taking delivery of my Cooper and reading the forums diligently.
On the other hand, I had been leaning towards getting a Mini since January 2009. I visited a dealership with a friend who wanted to order a Clubman and was impressed by what I saw. Mind you I have NEVER owned a non-Volkswagen in my entire driving life but my last one (2001 GTi) had been fun, lasted me over 12 years but was not going to be easy to replace. I've always been a fan of small cars and VW has effectively abandoned the small car market in the US. So, it made sense to gravitate towards Mini.....especially I wasn't willing to take a chance on a new Fiat 500 or SMART car.
I would visit the MINIUSA configurator every few months for over 4 years, fine tuning what options and colors I'd want and how much I'd be willing to spend on a new car.
So, when I finally did buy one this year, it had been a well-thought out decision. No regrets so far, although I am a little nervous about what I've heard regarding clutch durability.
If I had read this forum earlier I wouldn't be the proud new owner of an R56.
Old Dec 22, 2013 | 06:36 PM
  #58
onefish2's Avatar
onefish2
I went in for the recall last month. The dealership wound up replacing the timing chain as it was stretched to 70mm. It never made that death rattle noise.
Clutch was replaced at 28k and now at 37k they replace the timing chain. Gotta love these cars.
Old Dec 22, 2013 | 06:38 PM
  #59
onefish2's Avatar
onefish2
If you lease and live near a MINI dealer then by all means go get yourself a MINI if not then I would not recommend this car to anyone.
I bought my car and its been paid off for a while so I am stuck with it.
Old Dec 22, 2013 | 06:44 PM
  #60
komet155's Avatar
komet155
ONLY 28000 miles on your first clutch? That's ridiculous. I had 173000 on the ORIGINAL clutch on my GTi 1.8t when I sold the car.
Old Dec 22, 2013 | 06:46 PM
  #61
onefish2's Avatar
onefish2
Known issue with clutches on 2008 factory JCWs. MINI went to a newer model clutch in 2009 I believe.
Old Dec 22, 2013 | 10:49 PM
  #62
Ponyrider's Avatar
Ponyrider
I have put 36k miles on my 2012 Mini hardtop non S in 2 years.
Other than scheduled maintenance, the car has not had one problem.
If I had read this forum or Porsche Pete's Boxster Board prior to purchase, I would not have had the pleasure of driving the Mini or my 2001 Boxster S for 123k miles!
Old Dec 23, 2013 | 05:43 AM
  #63
Ronin82's Avatar
Ronin82
i just got rid of my R56. it was nothing but a year long Migrane. About $6300 in repair and maintenance. its givin me a very sour outlook on european cars and just a personal opinion that BMW/Mini are only as good as their warranties,... and thats still 50/50
Old Dec 23, 2013 | 06:14 AM
  #64
Spridget's Avatar
Spridget
If you're buying a pre-owned MINI with an unknown history, my opinion is that you shouldn't be all that surprised if problems turn up. Yes, it could have been pampered by the previous owner and be a very good car; or it could have been caned within an inch of its life, with oil changes when the light prompted at 15K, and then prettied up for sale when it started to get sick. I bought mine new, followed the break-in guidelines, I change oil at 5K, take it in for regular check-ups, etc. Aside from the aux water pump recall and turbo oil line heat shield fitment, reliability has been exemplary. Yes, every car is different; but with an unknown history on ANY vehicle, you're taking your chances. Ask any MG owner... ;-)
Just my opinion, and I realize there are exceptions!
Spridget
Old Dec 23, 2013 | 10:55 AM
  #65
komet155's Avatar
komet155
I think BMW/Mini (and the whole auto industry for the most part) has shifted closer to building cars with disposability in mind....an increasing emphasis on electronics which tend to have a shorter trip to obsolescence than mechanical components as well as increased use of cheaper materials...more plastics, ceramics, thinner gauge sheetmetal... they don't really want you to keep a car running for 10+ years. The more frequently they can get you into a brand new car means a greater percentage of the time you own the car will be exposed to their dealer network (more $$$ for them).
I was poking around under the hood of my Justa Cooper yesterday and marveled at how cheap and flimsy everything seemed. If you ever get to see pictures of wrecked Minis (as some salvage yards show in their Ebay listings) the cars tend to crumple pretty easily. Yes, it makes for a safer occupant but again, win-win for the manufacturer...you'd either have to buy that many more replacement parts to get it running again or....buy a new one.
Sorrry for my long-winded speech. ;-)
Old Dec 23, 2013 | 08:07 PM
  #66
Spridget's Avatar
Spridget
Komet... I suspect that what you're seeing isn't MINI aiming for "disposablity," but is instead the result of mandates that demand certain levels of fuel economy (hence the lighter-weight materials, etc.) and crash safety that requires the front structure to deform in specific ways to minimize intrusion into the cabin. Obvious, of course, but I only say that to stress that such design is industry-wide, and certainly not unique to MINI. The heavy emphasis on electronic engine controls is likewise the result of laws defining economy and emissions management. In my opinion, however, MINI has gone overboard with the digital management of all the body electrics. Having to reprogram the window lifts? Come now, really... All that to say that modern cars, with all their technical sophistication, actually are capable of lasting a very long time. Even MINIs. ;-)
Spridget
Old Dec 24, 2013 | 01:27 AM
  #67
komet155's Avatar
komet155
I hope you're right Spridget. I tend to buy my cars new and keep them over 10 years. I do know keeping on top of maintenance and small repairs before they turn into big ones is key. I'm just surprised at how much flimsier today's materials are.
As far as Mini's overemphasis on electric controls and programming for non-government mandated systems, I'm sure it's as much for keeping the owner dependent on sophisticated repair equipment as it is for advanced engineering purposes.
Old Dec 24, 2013 | 03:21 AM
  #68
mrluckypa's Avatar
mrluckypa
Hey Gorilla,
Unfair statement!!!! You bought it with 45K on the odometer. Do you know if the prior owner performed required maintenance? or what about abusing it or was it modded and then retrofitted prior to sale. When you buy used, you take chances especially if it is not MINI Next. You just can't blame it on MINI. This just might be your fault.
Old Dec 24, 2013 | 03:50 AM
  #69
linak's Avatar
linak
I agree and this statement could apply to any used vehicle - but I believe even more so with MINIs. When I last fueled up my local station attendant (yes, I'm in NJ) said he could tell who owned vs. leased their MINIs. Owners - premium; lessee - regular. It's a simple example but shows how some folks do not do the right thing for their cars regardless of what's in an owners manual. So who's to say what else has or hasn't been done properly?
Old Dec 24, 2013 | 04:22 AM
  #70
danjreed's Avatar
danjreed
You do realize that EVERY automaker does this now. Ford/GM/Chrysler/Toyota/Honda/VW.. It's all custom VIN ID coding for modules, it's hardly a "Mini/BMW only" thing. And no, your average joe can't do it without a proper scan tool , software, internet connection, and training.
As for flimsy stuff, it's a combination of cost, weight savings, safety, and corrosion issues. I'll gladly take a crash in my Mini over a 1968 Mustang.
Old Dec 24, 2013 | 06:21 AM
  #71
komet155's Avatar
komet155
I did not know that danjreed. I have only owned 6 cars in 27 years of driving, only 2 of those were used and all were Volkswagens until this 6th one, a 2013 Cooper hardtop.
I just found it surprising that I can press my palm into the center of my front bumper and feel it physically give under the pressure. That's pretty flimsy IMHO.
Old Dec 24, 2013 | 06:43 AM
  #72
MikewithaMini's Avatar
MikewithaMini
komet I think you are pushing only on the bumper cover. You can pull that off in a few minutes and that reveals the real works which seems to be fairly efficient in protecting the passenger cabin. I've seen some pretty nasty looking crash pictures, including one local, where the occupants purportedly walked away. These little cars are pretty sophisticated compared to my first new car - '73 Super Beetle.
Old Dec 24, 2013 | 07:07 AM
  #73
Herleman's Avatar
Herleman
My 09 Justa is kinda like the Energizer Bunny. No issues at all.
The only thing I've ever wished for was Window buttons on the door. Everything else is just fine.
Old Dec 24, 2013 | 07:19 AM
  #74
komet155's Avatar
komet155
My 2001 (mk4) GTi also had a plastic bumper cover, but it was strong enough to stand fast against mere hand pressure. My point isnt so much that plastic parts are flimsy (since ABS plastic has been effectively used for bumper covers since the 80's) but that it's surpising that a bumper cover which is expected to withstand light taps in low speed situations is so flimsy that I can press in close to an inch with hand pressure.
Old Dec 24, 2013 | 09:39 AM
  #75
danjreed's Avatar
danjreed
So you would rather have the foam insert be pressed firm against the skin so in a low speed impact the bumper skin gets compressed between the foam and object pressing on the bumper and causing a paint crease? No thanks.
Yes there is an "air space" between the bumper skin and the foam/rebar underneath.
If it bothers you, fill it with expanding foam and hope no one bumper taps you.
