R56 New MCS owner, ride too harsh - Koni FSDs or non-runflats? or both?
Old Sep 14, 2013 | 05:19 PM
  #26
yesti's Avatar
yesti
Originally Posted by seabeast
Seriously? I think you've got that backwards: tires are much firmer with high pressure than with low, unless the pressure is so low that you're riding on the rims (which can't happen with run-flats, anyway).
I found the ride on my run-flats improved (a little) after I lowered the pressure a few pounds from stock.
/Seabeast
Surprised me too. I usually put a few more psi than stock in my tires and when I did that to the run flats I was AMAZED how much the ride changed. You should try it, what have you got to lose? If you don't like it let the air back out.
I also speculate it takes you off the concrete sidewalls so you're actually riding on air instead.
Edit: Also note that you will sacrifice a little turn in sharpness when switching to non-run flats. Everything with cars is a trade-off...
Old Sep 14, 2013 | 05:55 PM
  #27
twocute's Avatar
twocute
We have an'04 S with 16" wheels that greatly benefitted from FSD's and non-rfts.
We also have an '08 Clubman S with 16s (non-rfts). It also has FSDs, but we didn't notice nearly as much of an improvement with the FSDs.
Old Sep 17, 2013 | 07:48 PM
  #28
Ewc's Avatar
Ewc
Originally Posted by Ewc
I just bought a 2012 JCW with 17" tires and regular suspension. I replaced the standard RFTs with Bridgestone Potenza RE960AS RFTs, which are third gen RFTs that are supposed to ride like normal tires. Impact harshness is much reduced and I don't cringe as much hitting manholes and other road bumps.
The main issue, however, is the short suspension travel. Thus, although the tires were a big improvement, I ordered a set of FSDs to hopefully take the edge off of larger impacts. I had FSDs on my old e46 vert and they made a huge difference in reducing cowl shake and impact harshness. I expect the same on the Mini and will report back after install.
Just had the FSDs installed today at helix, and as I hoped, they made a HUGE difference. The tires in conjunction with the shocks make the car ride almost luxurious. Sharp bumps such as expansion joints are much more muted. Hitting a manhole cover dead on still results in a big thump, but again it is more muted vs stock where it would result in a huge crash that you feel in your kidneys. The car simply glides over smaller bumps and undulations.
The interior also seems slightly quieter as well, possibly because the shocks absorb small vibrations that were previously transmitted by the rock hard tires and overly soft stock shocks.
Overall I'm very happy with my investment in tires and shocks. If anyone is on the fence just do both right now. I think the shocks and tires were equally helpful in helping the ride. Together, they are amazing.
Old Sep 17, 2013 | 08:59 PM
  #29
fastNugly's Avatar
fastNugly
Would you happen to know the part number(s) of the shocks and what would someone be looking to pay for just the shocks?
Also....anyone know what the smallest rim I can run with JCW brakes?
Currently my mini has 18's and I'm debating whether to go none run flat tires for the 18's or downgrading a size or 2, but not sure what fits and doesn't.
Still 2 weeks new of owning my clubman
Old Sep 18, 2013 | 03:28 AM
  #30
richardsperry's Avatar
richardsperry
While the ride and impact harshness will be improved, you do lose turn in sharpness, transition feedback, and go cart like feel. Remember, everything is a trade off. I'm not saying it's a bad trade off, but there is no free lunch...
Oh and about the brakes, it depends on what size rotors you have. Usually the smallest you car go is 17", and even then you need enough offset and the contour of the rim has to be right.
Old Sep 18, 2013 | 03:46 AM
  #31
veggivet's Avatar
veggivet
Originally Posted by RiskyBusiness
I've read many many threads about non runflats and FSDs; looking for opinions as to the relative improvement between the two. It seems that everyone does one or the other, but few have done both.
I have, and the changes transformed the car. If you can't do both, I would change the tires out first.
Old Sep 18, 2013 | 03:59 AM
  #32
Ewc's Avatar
Ewc
Go to www.waymotorworks.com to order. I got my Koni FSD shocks on sale for $664 including shipping. They retail for about $800.
I believe the smallest size on a JCW is 17" because you need the wheel to clear the Brembo brakes up front. Call Tirerack for recommendations.
Old Sep 18, 2013 | 04:05 AM
  #33
Ewc's Avatar
Ewc
True, there is a slight trade off in transition feel. However the shocks do firm up quickly in the turns and hold the line. My initial impression is I do not lose very much sharpness. The stock suspension is not all that sharp to begin with. I got a fair amount of body roll with the stock suspension.
Plus if your turn is bumpy at all, the FSDs are far superior to stock in absorbing the bumps and allowing you to hold your line vs bumping and skipping thorough the turn.
For a daily driver there is no question any minor loss in transition feel is well worth it. If you want a race car get some Ohlins coilovers.
Old Oct 2, 2013 | 05:54 PM
  #34
RiskyBusiness's Avatar
RiskyBusiness
Coming back - did the FSDs - still have the runflats (mainly because there seem to be no buyers for them - I've been watching others for sale on this site).
My first impression: harshness down 60-70%. Loss of sharpness/feel 10%. And I agree with the above comment that in a turn with any bumps they're much better because you don't skip a bit sideways.
Very good tradeoff for me since I live in an area with at best average roads. Thank you everyone for your help with this!
Kimolaoha
Dec 5, 2020 09:32 PM
eatsleepautox
Oct 30, 2015 06:46 AM
blackie
Aug 25, 2015 09:08 PM
Emnotek
Aug 13, 2015 05:47 PM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
