R56 Winter tires
Old Aug 1, 2013 | 11:42 AM
Steve_in_NH's Avatar
Steve_in_NH
Have an '07 MCS with 195/55/16 " summer tires. (Stock). Was given a set of 4 winter tires not mounted. Size 205/55/16 off a Mercedes. Question is will these winter tires fit on my stock rims? Thanks in advance for any help.
Old Aug 1, 2013 | 08:41 PM
The Angry Pumkin's Avatar
The Angry Pumkin
I would say yes but they will be a bit wider and taller.
Old Aug 1, 2013 | 08:42 PM
The Angry Pumkin
Forgot to say my winter meats are 205/50R16's
Old Aug 2, 2013 | 05:06 AM
aklucsarits's Avatar
aklucsarits
I have a set of stock OE 16" wheels with Pirelli Sotto Zero 2 winter tires on them that are that same size, 205/55/16. (I bought the 205/55/16 because that size was nearly $100 cheaper than the 205/50/16 for some reason.) The tires fit fine except when the steering wheel is turned full lock they rub very slightly on the inner fender liner. I have only ever experienced this in parking manuvers.
So yes, use the free tires you were given. They will be fine.
Old Aug 3, 2013 | 05:13 PM
son-of-mini's Avatar
son-of-mini
I suggest you mount those tires on a separate set of wheels. It makes the changeovers much easier.
Old Aug 4, 2013 | 06:10 AM
richardsperry's Avatar
richardsperry
Will they fit? Yes Are they ideal? No.
The object of winter tires is to get down through the snow to the pavement. You don't really want a wider tire in the winter....
My summer tires are 215-45-17's and for winter I've got 195-55-16's
Waszak
Oct 21, 2017 05:55 PM
Ntety
Sep 2, 2015 08:39 PM
