R56 Craven Short Shifter and NM cover
Old Jul 7, 2013 | 12:06 AM
speedkills66's Avatar
speedkills66
I recently installed the Craven Adj Short Shifter and I did not put a cover over the shift linkage under the car.
I'm having second thoughts and I was hoping someone could answer definitively:
Do the Craven Short Shifter and NM cover work well together?
Specifically: Can I use the lowest setting on the shifter with no rubbing or other adverse effects?
I'm either going to make a cover or buy the NM one but only if I can use the lowest setting on the craven shifter
Thanks in advance.
Old Jul 7, 2013 | 12:32 AM
ra2fanatic's Avatar
ra2fanatic
At lowest with the NM cover...it won't rub. I had this setup before and you'll be fine. Please don't run w/o a cover.
Old Jul 7, 2013 | 12:45 AM
onefish2's Avatar
onefish2
I had the Craven Speed short shifter installed for well over 2 years with no cover and never had a problem. I swapped out my exhaust last year and had my mechanic install the NM cover at that time. I have always had the short shifter on its lowest setting. It does not rub and the two work well together.
Old Jul 7, 2013 | 01:20 PM
speedkills66
Thanks all. Just ordered the cover from Way.
Should be a quick install now that the hard part is out of the way.
Worth it for the peace of mind.
minimofo
Nov 5, 2015 08:40 AM
cb_smalls
Aug 31, 2015 06:13 AM
jziran
Aug 24, 2015 04:50 PM
