R56 r56 manual trans oil?
#51
I went with the Amsoil Syncromesh MTF for my '07 MCS. Two quarts cost me $26 from Napa, and they had them in stock. Took all of about 15 minutes to change the fluid, and the old stuff was pretty clean at 30k. Still, the transmission was getting a little clunky, and the new fluid totally cleared it up.
Lifetime oil, my ***. Next, they're going try telling me I can go 15k on an oil change or something silly like that.
#53
#54
Thanks...I'll keep this in mind. I do live in a cold climate, but I expect some degree of stiffness when the transmission is cold. I do mostly highway driving anyway, so it warms up quickly.
#56
#62
EDIT: wow I'm really failing at reading this morning. Since you have the factory diff if that is the fluid Amsoil recommends for the mini transmission then you're fine to put it in.
#64
#65
#66
Very false. Gear oil, some specifically marketed MTL, motor oil. All things I'd call "common" in Manual Transmissions/transaxles. ATF? I can't think of one car off the top of my head that comes with it.
I've seen ATF used in power steering systems, not manual transmissions though.
#67
Lets see:
Ford, Mazda, GM, Chrysler, Well, crap anything with a BorgWarner T5 takes it.
Did you know that Honda cars take 5w30 motor oil for older manual transaxles?
Lots of BMWs take AFT as well for the gearbox. - 98 E36 M3 requires ATF for the transmission... Several modern manual gearboxes use ATF for gas mileage reasons as well as tighter clearances and a better "feel". All T-5's, T-56's, and Tremec's use ATF. It's fairly common (and nice).
So, take your "very false" and have a nice day!
Some day I'll tell you chillen about HSMO fluid, and brake systems that use ATF for the brake booster!
edit - Added this listing showing many, many modern cars taking ATF in the gearbox. - http://www.carquestprofessionals.com...0%206.6.13.pdf
#68
GL-5 can be very, very harsh to internal brass hardware and blocker rings.
#69
You may be right about a convential GL-5. However, I did my research. Mobil 1 synthetic gear oil is different. From Mobil MSDS:
'...highest level of inherent formulation stability and helps to protect against thermal and oxidative degradation, wear and corrosion, viscosity loss associated with premature shearing.'
'Excellent rust, staining and corrosion protection of copper and its alloys. Helps to reduce wear. Long component life.'
Brass is a copper alloy. Just because it meets a spec, doesn't mean it can't exceed it. It's my understanding that Valvoline also makes one that meets GL-4 and 5 that is safe.
#74
Tex MTL94 (OEM product - note the GL-4 rating)
Pro+Plus Gold 75w85 (Note the GL-4 rating)
I'd add that Syncromesh (Pennzoil) is pretty good, but its not a synthetic fluid. I've run it in several cars in the past with no problems.
You could run a quality AFT as well as noted above.
edit - note added - http://www.mobiloil.com/USA-English/..._Gear_Oil.aspx
Note - that Mobil 1 does not recommend a GL-5 product in a trans.
"There are transmission applications that recommend API GL-4 type products where we would not recommend using an API GL-5 fluid because transmissions typically have components made from “yellow” metals. However real axles where GL-4 fluids are recommended do not have “yellow” metal components. As a result, the application of an API GL-5 fluid is acceptable."
"real axles = rear axles".
#75
I suppose I might try the Valvoline gear lube or Syncromesh next time. I find it interesting that Valvoline meets GL-4 and GL-5 simultaneously. I think Exxon/Mobil is just being politically correct by saying their LS gear lube is not recommended when it is specifically designed for 'limited-slip differentials, final drives, transfer cases and other gear applications.' I also wonder if they are referring to an older GL-5 in that link, as the current one is safe for copper/brass.
