R56 What gauges are you running?
Old Apr 3, 2013 | 03:55 PM
  #51
byron h's Avatar
byron h
Originally Posted by bmwr606
it is not a pressure sensor, but a pressure activated switch to turn on the idiot light
scott
Scott,
My Bentley Manual states the following for the N16 and N18 engines: "Oil pump output is based on the characteristic map within the ECM and feedback from the oil pressure sensor." The manual also shows on the elecrtical diagrams a engine oil pressure sensor B6571a. The manual shows the location of the pressure switch for the N12 and N14 engines but does not give different switch or sensor locations for the N16 and N18 engines. They may have replaced the pressure switch with a pressure sensor on the newer engines. The wiring diagrams for the N12 and N14 show a pressure switch B6231.
Morris, 2011 MC, PW/B
Old Apr 3, 2013 | 04:21 PM
  #52
bmwr606's Avatar
bmwr606
Originally Posted by byron h
Scott,
interesting, realoem shows a "pressure switch" for my n18 but no "pressure sensor"
i am going to talk to a mechanic at the dealer and get to the bottom of the oil pressure and temperature issue
scott
Old Apr 3, 2013 | 04:44 PM
  #53
Little Black Mini's Avatar
Little Black Mini
Very interesting. Let us know what you find out from Scangage or the dealership.
Old Apr 4, 2013 | 12:08 PM
  #54
rahul325's Avatar
rahul325
Originally Posted by DneprDave
It sounds like newer MINIs have an oil temperature sensor, because the ScanGauge wouldn't read oil temperature without a temperature sensor.
Dave
newer = ?? 09 onwards ?
Old Apr 4, 2013 | 12:17 PM
  #55
DneprDave's Avatar
DneprDave
That's something you should ask a MINI tech. It would definitely be on 20011 and newer engines.
Dave
Old Apr 13, 2013 | 04:22 PM
  #56
komet155's Avatar
komet155
Did you receive your gauges yet? Will they be easy to install? Looking forward to seeing pictures.
Originally Posted by JJKNZ
I ordered 2-5/8 boost and oil pressure gauges and 2-1/16 oil and water temp gauges that perfectly match my black face, chrome ring JWC tach down to the
Gauge face color,lighting and text and I comes with all ness art hardware except sensor port fittings
Old Apr 13, 2013 | 04:41 PM
  #57
flakoR56's Avatar
flakoR56
what i order was the alta pod and an AEM boost gauge for now later on ill see what else to get
Old Apr 13, 2013 | 07:11 PM
  #58
JJKNZ's Avatar
JJKNZ
I should be getting my gauges in a few days.
Old Apr 13, 2013 | 10:44 PM
  #59
JJKNZ's Avatar
JJKNZ
I should be receiving my gauges in a few days and will post pictures when I get them
Old Apr 13, 2013 | 11:41 PM
  #60
JJKNZ's Avatar
JJKNZ
Here is a photo of my gauge face plate art work
Old Apr 14, 2013 | 12:20 AM
  #61
flakoR56's Avatar
flakoR56
thats freaking nice bro where are you mounting them?
Old Apr 14, 2013 | 12:29 AM
  #62
JJKNZ's Avatar
JJKNZ
Using 4 60 mm craven speed pods
Old Apr 15, 2013 | 07:46 PM
  #63
Little Black Mini
I used ABS, rather than PVC plastic, because it is already colored black, I polished the printing off of the pipe pods and waxed them, they came out real nice and there's no paint that could eventually peel off.
I installed the oil temperature gauge because of discussions I read on these forums. Manufacturers don't install oil temperature gauges, at least I've never seen one in any production car, so I've had no experience tracking oil temperature, I was disappointed that it gave me no useful information.
I don't track my car, maybe if I did, I'd see a difference in temperature between the oil and the water. Even with spirited street driving, my oil and water temperature gages read about the same. For me, the oil temperature gauge is unnecessary. I'll keep it for a balanced look until I get the water/meth injection system.
Dave
Dave,
Not sure where you live but the oil temp gauge can be an engine saver in hot regions. My 2010 Camaro SS RS has an OT gauge and it was a wake up call one day when running some back roads and I didn't realize the ambient air temp was well over 100 degrees. I've since installed an oil cooler in that car. The tuned 6.2 liter does run hot when your getting on it. Maybe the mini does not run as hot but with a turbo I think the risk of high oil temp is real.
Dave
Old Apr 15, 2013 | 08:44 PM
  #64
flakoR56's Avatar
flakoR56
can any of you guy tell me what do i need to install a oil temp gauge on my r56? i have the AEM gauges
Old Dec 23, 2015 | 01:47 PM
  #65
Lex2008's Avatar
Lex2008
Check out my post boyz,
https://www.northamericanmotoring.co...for-300-a.html
silence2-38554
98
Sep 21, 2016 02:52 PM
AdrenaliNate
Nov 4, 2015 07:26 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
tylewis
Aug 18, 2015 06:53 AM
