R56 First must do mod to a MINI
Old Mar 15, 2013 | 01:43 PM
  #26
solskjaer1999's Avatar
solskjaer1999
Originally Posted by BHat1Trey
does plasti-dip scratch off easily? i know you can peel it off, but how good is it at staying on?
Plastidip does a great job of staying on plus it's cheap. A high velocity pebble will scratch it though, but it is surprisingly durable. As for the chrome trim around the car, I wouldn't and didn't Plastidip it. I bought the blackout vinyl strip on OutMotoring (about $12). Just spray the trim with some rubbing alcohol to clean it, then install a section, use a hairdryer to heat it up to get a good fit, then use a razor blade to trim the excess. It's worked perfectly for me and I installed it in November in my garage when is was about 30 degrees outside. You should have no problems with good weather.
Old Mar 15, 2013 | 02:51 PM
  #27
Braminator's Avatar
Braminator
Does not scratch easy. Things actually bounce off.
Check this out
Old Mar 15, 2013 | 05:10 PM
  #28
BHat1Trey's Avatar
BHat1Trey
Oh, nice! I wish these things were just obtainable locally. I would so do it this weekend. Thanks for the info.
Old Mar 15, 2013 | 05:30 PM
  #29
StPeteAPB's Avatar
StPeteAPB
Originally Posted by blknblu
tint the windows
+1
Old Mar 16, 2013 | 06:58 PM
  #30
bigbacon's Avatar
bigbacon
i agree with a good window tint, we are planning this. SO much glass and gets SO hot in the summer.
Old Mar 16, 2013 | 08:56 PM
  #31
KilmerPT's Avatar
KilmerPT
Originally Posted by Capt_bj
get a rear sway bar
I've heard this often since 2002
my question is
can you explain EXACTLY what is to be gained?
When changing brake pads the answer is: much less brake dust, car looks better and needs to be cleaned less frequently
I've yet to find an average owner who could tell me what they expected to get from their new sway bar other that being able to tell folks they had one . . .
btw, doesn't the MINI already HAVE a sway bar????
is a sway bar 'better than'
tires
brakes
driving lessons
Isn't the idea of getting a bigger swaybar to reduce understeer so you can go faster at turns and have more gokart-like driving experience than stock?
Old Mar 16, 2013 | 08:59 PM
  #32
RobMuntean's Avatar
RobMuntean
Correct my friend!!! And I love it now! On ramps I could only do 40ish but since I put the sway bar on, I do much more than that(when I'm driving alone and with no drivers behind or in front of me).
Old Mar 17, 2013 | 03:34 AM
  #33
Opeth's Avatar
Opeth
2 very cheap and effective mods (and the only I did):
1. Stubby antenna.
2. Silver bulbs for the white blinkers to get rid of the ugly orange "egg yolk"
Old Mar 17, 2013 | 04:39 AM
  #34
bratling's Avatar
bratling
Super Moderator
To reduce body roll in corners.
Old Mar 18, 2013 | 08:37 PM
  #35
john171's Avatar
john171
You can purchase Plastidip at Lowe's, Home Depot and I think Ace Hardware, probably a lot of other places, do a Google.
Old Mar 18, 2013 | 08:41 PM
  #36
john171's Avatar
john171
Front and rear strut bars, Light In-Sight, Stubby antenna, and side stone guards.
Old Mar 19, 2013 | 05:52 PM
  #37
BnR's Avatar
BnR
After checking oil for the first time the dip stick either is getting replaced or dremeled. Next thing will be tint.
Old Apr 1, 2013 | 02:52 PM
  #38
myR56S's Avatar
myR56S
Oh boy, here is my 2 cents:
I wanted to change the way my N14 responded first:
Changed the cold side intercooler charge pipe. Woke my N14 up a little.
Changed the intake to a CAI. Woke up my N14 further.
Changed the exhaust to a bigger diameter. Icing on the N14 cake (and a tune, lol).
But I agree, 22mm sway bar is the best spent money from the get go. I will do mine when I get springs.
Old May 8, 2013 | 11:13 AM
  #39
Muddy4DSM's Avatar
Muddy4DSM
Is there a particular brand of 22mm roll bar you guys are installing or at least a common source to get one?
Old May 8, 2013 | 02:10 PM
  #40
Braminator's Avatar
Braminator
Old May 8, 2013 | 02:40 PM
  #41
TheBigNewt's Avatar
TheBigNewt
Mine's H-Sport, installed by Way Motor Works, but it's 19mm. My advice is that you not get too thick of a rear swaybar especially if you are not a track driver. The risk is that instead of less understeer (which I definitely noticed right away in corners) you could oversteer especially if you go too fast in a turn and have to lift off throttle. Then the car will swap ends, never a good thing. Careful.
Old May 8, 2013 | 04:40 PM
  #42
nowhereman's Avatar
nowhereman
heres the list of mods we did all on the cheap and all well worth it.
ebay aluminum strut tower bars (front and rear can be had for under $100 delivered)
a CAI
one ball exhaust mod
window tint
led plate bulbs
EBC Red Stuff Pads
Soon we will be plasti-dipping the white roof gloss black to match the sunroof and be more contiguous and the wheels to match.
total for all upgrades is probably about $500 or so depending upon where you get parts, tint etc and if you have someone do the work for you or do it yourself.
all make our R53 a much better car to drive and look at.
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
