R56 Painful cooper s car seat... Solution needed!!!
Old Dec 20, 2012 | 01:09 PM
  #26
Minifrench's Avatar
Minifrench
Originally Posted by bart1
For the door, maybe take off your panel and see if the moisture barrier is intact.
unfortunately there is no barrier in the gen 2.
Old Dec 20, 2012 | 02:30 PM
  #27
Bponce23's Avatar
Bponce23
well i'm sure it isn't a lumbar issue... i think i'm going to go to a pro upholsterer and see what the charge. I really want to keep the look of the seats... have them match and stuff... i got the cloth/ all black seats...
Old Dec 20, 2012 | 02:43 PM
  #28
Luckyelfie's Avatar
Luckyelfie
I found the lounge leather seats to be the most comfortable on my larger frame. You should try them out.
Old Dec 20, 2012 | 02:53 PM
  #29
Bponce23's Avatar
Bponce23
WOO HOO.. i just talked to a local upholstery shop... 150-180 to redo the seat part with softer foam....
problem is the seat heaters... said they are glued on and are a real pain to deal with ... i said that i don't give a crap about the seat heater and he can cut them off for all i care... as long as he gives me a softer seat... my fart will warm up the seats on cold days
Old Jan 2, 2013 | 08:31 PM
  #30
pw16's Avatar
pw16
I have the same problem. Sometimes even my smallest two toes go numb. My position in the seat makes a difference but doesn't alleviate the problem entirely.
I have the base seats and retrofitted the lumbar. The lumbar makes a big difference for my back. I regret trying to save money by getting the base seats.
Old Jan 3, 2013 | 05:54 AM
  #31
Fastlane's Avatar
Fastlane
Not sure if anyone else has noticed this, but I think it also contributes to the left bolster comfort issue....
On my r50 cooper, the drivers seat was exactly centered with the steering wheel. When I first got my r56, I immediately noticed that the seat was offset to the right by as much as an inch or so. IMO, I tried to compensate for this (not really on purpose) by shifting my body to the left in the seat. This puts more pressure on the left thigh against the bolster.....hence the discomfort. That's my theory, anyway.
Old Jan 3, 2013 | 12:09 PM
  #32
Minifrench's Avatar
Minifrench
I don't have anymore this pressure on my leg since I set up my seat higher (much higher). It helps to support more "weight" of my leg. The higher I go the more comfortable it is and when i go back to a very low set up (very sporty position) the pain is coming back.
You should try.
Finally I decided to just feel a little bit the pressure but having a more "sporty" position. Higher I was like driving a 4X4. It is a compromise.
Old Jan 3, 2013 | 01:55 PM
  #33
MNIPWR's Avatar
MNIPWR
For the people with this issue have you ever thought about sliding your seat backwards?
Old Apr 14, 2013 | 09:21 AM
  #34
jbat66's Avatar
jbat66
I went on a 14 hour drive in my wifes Countryman, but before hand I got a pair of seat pads from wallyworld. (walmart) The seat pads are foam inside of a zipped up liner. I took the foam out cut the sides off so they laid down in the bottom of the seat between the bolsters. I then put the foam back into the liner. I stack both on top of each other and I have a great ride now. I just need to find a way to make it to I don't have to readjust them everytime I get into the car.
Originally Posted by jbat66
Funny I have the same problem in my Convertible S 2013, but more so in my wife's S Countryman 2012.
I have been playing with the idea of making a pad, that just fit between the bolsters so that I'm up a little bit, and that would make the bolsters not "pinch" as much.
I will be watching this thread for more ideas.
Old Apr 14, 2013 | 09:48 AM
  #35
mrluckypa's Avatar
mrluckypa
Sport seats (that come standard on S) are the only seats that I can sit it comfortably for at least 8 hours any other cause back pain I just can't have lumbar support thanks to a dumb *** 16 year old who broke my vertebrae three years ago.
Seats in my CM are just perfect and even better when I turn the heat on.
Old Apr 14, 2013 | 10:32 PM
  #36
MNIPWR's Avatar
MNIPWR
Just to throw this out there. The human Body is not supposed to be sitting for that long. So no kidding if you start to feel uncomfortable. Common sense people. If you can sit 8 hours anywhere before you back hurts after your broken back then you really can't complain. I can sit for about 30-45min before I feel discomfort. You own a mini people. It is not designed to be comfortable. It is designed to be fun!
Old May 14, 2013 | 03:48 PM
  #37
Gator Vlad's Avatar
Gator Vlad
Do NOT get Recaro seats! Very painful!
SosoMINI
Nov 22, 2015 03:17 PM
1chaos52
Aug 24, 2015 01:28 PM
bctf1
Aug 6, 2015 12:55 PM
