R56 Cant i isntall in my r56 N18 engine a bov?
Old Jul 1, 2012 | 02:19 PM
Mini Cooper r56 Pr's Avatar
Mini Cooper r56 Pr
I would like to know is that posible because some people had told me that the n18 engine do not do vacum i have a aftermarket HKS bov but i would like to know if have to buy anything else to install it and works perfectly let me know thanks!
Old Jul 2, 2012 | 06:09 AM
bluefox280's Avatar
bluefox280
Remember that the N14 and N18 are closed-loop boost systems.
That means the unused boost, when you throttle lift, is diverted back into the intake system.
Venting boost into atmosphere can results in a fuel trim issue as the ECU thinks the unused boost is still accounted for in the intake system.
Search and you'll find owners with them.
- Erik
Old Jul 2, 2012 | 10:04 PM
Mini Cooper r56 Pr
Forge Bov for r56 n18 engine
I been searching and i saw that the forge bov cant be install in r60 that the engine code is (Turbo N18B16MO engine) that is the same for the mini cooper s r56 2011 turbo so it cant be install in the r56 but i would like to know the feedback about it if some one have install it in a r56 n18 engine??? Thanks
Old Jul 3, 2012 | 05:14 AM
richardsperry's Avatar
richardsperry
Can you? Sure you can. Anything is possible if you toss enough time and money at it.
Do you want or need to? Nope...
theunlimitedone
Aug 31, 2015 08:17 PM
damncajun
Aug 17, 2015 08:25 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
flredmini
Aug 12, 2015 06:35 PM
