R56 Finally! Found source of rear bumper squeak...
Old Feb 20, 2012 | 02:29 PM
d@g's Avatar
d@g
This has been driving me crazy for months. I had a discernible metal on metal squeak coming from the rear, seemingly on the driver's side, mostly heard at low speed. I thought it was the license plate frame or the heat shield around the muffler, but I could reproduce it by pounding the bumper in random places.
The culprit was the metal-to-metal joint of the driver's side bumper support with the bumper carrier. Those two are mated to the wheel well on the driver's side rear with only a plastic expanding nut. I can't believe there was a metal to metal connection (now rusting) and just a flimsy plastic connector holding them together. I replaced the plastic nut with a stainless steel torx bolt and washer (a bit too long) and tightened that thing up TIGHT. No more rattle.
When I have more daylight, I'll put it up on a jack and get more room under there to work, sand the rust, recoat and isolate the parts better. It's SO nice not to hear that dang squeak.
Here's a shot of the temporary fix (fore and aft). The red piece is the bumper support and the black piece is the downward arm of the bumper carrier.
Old Mar 6, 2012 | 08:51 AM
Blue Scapegoat's Avatar
Blue Scapegoat
You sir, are a God among men.
Did the fix today, used some grade 8 hex bolts I had laying around. No more squeak thus far, and the bumper feels a lot more solid.
Now If I could just get the sunroof rattle to stop...
Old Mar 6, 2012 | 06:09 PM
ORazor's Avatar
ORazor
Dear God, is this the answer!? I plan to fully investigate tomorrow!
Old Mar 7, 2012 | 04:24 AM
d@g's Avatar
d@g
Maybe yes, and maybe no. I've solved three separate rear-end noise problems, all of which became really apparent with the rear seat and shelf out of the car.
The one above was mostly a squeaky metal on metal sound and was solved (as in noise gone). On the passenger side, I have a knocking sound that was due to the exhaust shield hitting the hollow plastic wheel well. I bent the exhaust shield to keep the two away from each other and that noise is gone.
I had another rattling sound that I found was due to the hard plastic edge on the foam bumper insert rattling against the inner bumper skin. That one was my own fault because I pulled down the foam to find the rear fog light wiring and didn't put it back in place correctly.
Now that's THREE separate rear end noises fixed BUT I STILL HAVE ONE . It's a low speed rear end clunking, kind of a hollow sound not unlike the problem with the exhaust shield hitting the wheel well. Not the spare carrier (tried riding without that). I'm hoping it's not the shock tower. Theres a TSB about excess weld metal not letting the shock mount seat flush with the body resulting in noise.
skippermini
Aug 12, 2015 10:05 PM
Aug 7, 2015 05:56 AM
bctf1
Aug 6, 2015 12:55 PM
