R56 brake rotor replacement.
I just placed order zimmerman rotors from pelican parts and I was wondering if I only replace rotors except brake pads.
because I replaced pads about 4months ago, i think it's still as good as new. Is it gonna be problem if i only replace rotors?
It will be fine. It should have been done at the same time, but it will all be fine in the end.
While there is nothing wrong with it, and so long you do a bed in process again twice, it's recommended to always replace your pads if you replace the rotors. The bed in process won't necessarily match the pads to the new rotors like they do when the pads are new as the old rotor pattern will still be there until it's worn down.
molala
Oct 2, 2015 01:53 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
