R56 What exactly does the rear "fog light" on my Mini do??
I had them on the 08 and I used them as a defense mechanism, at night when people would tailgate or come up on me fast, id flash them... believe it or not it would most likely make them freak out and let up off my boot
but other than that I did not use them
Let us know if you find out how. It's kind of lame to have them there and connected but with no way to turn them on.
I ordered the rear fogs on my soon-to-be 2012 MCS without knowing much about them, just because they were cheap.
Not to hijack the thread, but I do have a question regarding the toggle switches in the console as well as near the rear-view mirror. Anyone have a description of what each switch is for? I'm having a bugger of a time finding a place online with an accurate description of what they are all for.
Thanks all!
Jon
Thanks all!
Jon
Well when you get the car you will see little icons of what each one does above the toggle. Just from memory I think the ones by the mirror control the map reading lights and the mood lighting colors and speed of change. The toggles by the console control windows, rear fog, front fog, door and trunk lock.
Ah, cool, thanks for your help Automan!!
Alot of the pictures I could find didn't show enough close up detail
to make out each individual icon. I think I should have most of them
filled, unless one is for heated seats which I did not opt for.
Thanks again!
Jon
Thanks again!
Jon
Heated seats will be butttons on the extreme ends of the toggle switches. You shouldnt have any open toggles or anything like that except, on my car its by the mirror theres one thats open but I believe thats for a sunroof which I dont have.
It opens the least popular portal to Narnia.
Lol, I was just reading another thread and I wonder if the low beams werent on as it says the low beams must be on before the reverse fogs can come on. It was daytime so I doubt the lights were on.
In all cases it requires a trip to a dealer to have the fogs programmed into the system. If I remember right some dealers could not figure out how to do the programming or just refused to do it.
Depending on the build date some may or may not have the wiring in place. My '10 Clubman does not have the option but the wiring and even the bulbs are present.
hey,
I know this is an old thread, however I was searching for some answers on fog lights. I recently had an indicator light go on, showing the light bulb with a question mark in it. when I looked in the owners manual it said one of the exterior light is out. I have checked all the lights and they all work. I have fog lights however do not have toggle to make them work. one of them has a broken lens and maybe bulb. would that show on my indicator panel even if the lights can not be turned on?
2011 mini cooper fog lights
hey,
i was listening to a white-roof radio.. and they was talking about bmw was talking about getting rid of the rear fog light option for the us market... then Alex was saying its required by law over sea's to have rear fog lights... i think it kind of cool idea.. i have them on my r56.....
My rear fog lights got me pulled over by a NY state trooper a couple years ago! He asked me several times if they were aftermarket units -- expecting a different result each time? ;-) -- and didn't really seem satisfied with my answer that they were a $100 factory option. He was actually pleasant, though, and let me go after a few minutes.
hey,
https://www.northamericanmotoring.co...ml#post3255566
888.280.7799 | 6am - 5pm PST
Don't use rear fogs lights in good weather
I followed some Bozo for a while that had them on in clear weather. They (just one actually, as I recall) are very bright and really annoying to anyone behind you when it is not foggy.
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
