R56 Anybody using the Liquivac topside oil changer?
Old Mar 6, 2011 | 08:59 PM
mini on's Avatar
mini on
If so, how does it work for you?
Old Mar 6, 2011 | 09:51 PM
slinger688's Avatar
slinger688
I have a similar one from griots garage. It is my second suction extractor with the first one called topsider that worked for about 12 years. The current one is coming to about 6 years old already. It works fine extracting liquids as intended. I use it for oil and brake fluid (reservoir).
There is a lot of opinions about whether you should do an oil change with this. Just decide what is best for you. If you want to use it, it does work.
Old Mar 7, 2011 | 06:42 AM
Big Jim Swade's Avatar
Big Jim Swade
I won't use it, because it won't remove much of the contaminates and other stuff that might be laying on the bottom of the sump.
Old Mar 7, 2011 | 02:47 PM
ammodave's Avatar
ammodave
I have one (a Mityvac) that I use on the wifey's Volvo; works great. I haven't used it on my Mini because the dealer is still providing free oil changes. The 1st time I used it on the Volvo, I removed the drain plug after sucking out the oil and got less than an ounce of oil out. I'll use it on the Mini when the free oil changes run out.
Old Mar 7, 2011 | 03:15 PM
mini on's Avatar
mini on
Thanks for the input Dave. I ordered one from the distributer airpoweramerica and they have them cheaper than Amazon or Northern Tool. I went with a refurbished one for 30.00.
Old Mar 7, 2011 | 06:31 PM
ammodave's Avatar
ammodave
Not so fast! Are you sure you're not going to miss lying on your back on a cold garage floor while you fiddle with a reluctant drain plug? That's always been my favorite part of the experience.
Old Mar 8, 2011 | 05:37 AM
mini on's Avatar
mini on
And there I was looking up to the sky when a drop of oil hit me in the eye................
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Sep 2, 2015 09:05 AM
minicoclub
Aug 25, 2015 09:07 AM
