R56 Tire rotation question
Old Jan 17, 2011 | 10:07 AM
  #26
wpb mini's Avatar
wpb mini
Originally Posted by david in germany
By the way, tire rotation on the Mini is not only not covered but not recommended. I am a die hard tire rotator but I am pondering BMW/Mini recommendation on this. My present set of Conties will be run IAW BMW/Mini's thought process. If I die because of it I will let you all know
Well, let's hope not!
I know that some experts recommend no rotation for tires. I did a fair amount of reading on the subject, but after seeing the uneven wear that the front tires had in comparison to the rear tires, I decided that the rotation should be done. I was also surprised to see the Contis had worn so much in only 7500 miles. My previous cars' tires never wore that much. Perhaps the Conti tire is softer, or perhaps it's because the MINI is front wheel drive. Not really sure. But when it is time to replace the tires, I would rather start fresh with 4 new tires all with the same amount of tread, rather than getting 2 at a time and then having to get 2 more a few months down the road. Seems like a hassle.
Old Jan 17, 2011 | 10:14 AM
  #27
jcauseyfd's Avatar
jcauseyfd
Thanks wpb. It looks like they have changed the language, at least between 2008 and 2011. Just looked up the 2011 language which reads:
Swapping wheels among the axles
Depending on the individual use, front and rear tires may exhibit different wear and tear.
In order to maintain an even wear and tear, the wheels may be rotated between the axles. Your
MINI dealer will be glad to advise you.
Always check the inflation pressure after the tire rotation, if necessary change the pressure.
That last sentence implies to me that MINI recognizes tire rotations will be done.
This can be compared to the language in the 2008 manual:
The manufacturer of your MINI recommends that you do not swap the front wheels with the rear wheels.
Looks like they added the language about rotations starting with the 2010 models.
Old Jan 17, 2011 | 10:34 AM
  #28
Joe_914's Avatar
Joe_914
If you go to an autocross I would bet someone would do this for you for a fun run.
Changing tires is pretty much the easiet thnig in the world to do on your car.
Old Jan 17, 2011 | 01:34 PM
  #29
MCS Fever's Avatar
MCS Fever
Also somebody posted a video of cars loosing traction in the back and spinning out in the rain - when the best tires were rotated to the front IIRC. So rotate them often - or not at all !
Found it - post #6 here.
Old Jan 18, 2011 | 09:52 AM
  #30
wpb mini's Avatar
wpb mini
Thanks for the quote. I did not have my manual handy when I typed my response, but that is what my 2010 manual states.
thanks!
W0TM8
Dec 19, 2019 07:50 AM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
Mini'mon
Aug 16, 2015 04:15 PM
Mini'mon
Aug 16, 2015 12:47 PM
Emnotek
Aug 13, 2015 05:47 PM
