R56 DYI for Dos intake and sway bar
Hey all,
I just need a DYI for a Dos intake and a 22mm rear Sway bar, if anyone has suggestions please let me know, I have looked, probably in the wrong section though
Sway bar is pretty straight forward once you get under the car (I think it's like 6 bolts?), but you'll probably need to pop the rear struts out. Here's a link to k-huevo's spring DIY with instructions on removing the rear struts. I'll look around and see if I can find a sway bar DIY. I think redbull posted one a year or so ago.
https://www.northamericanmotoring.co...ll-how-to.html
Here's Red Bull's DIY. It's pretty straight forward.
https://www.northamericanmotoring.co...pressions.html
On the intake, I've provided a link to the Alta instructions. Use these as a guide for removing the stock box. Once the stock box is removed, it looks like you simply attach the business end of the DoS filter to the MAF sensor. (NOTE: be EXTREMELY careful with the MAF. It ain't cheap, and without it... it's bad news bears.) There is also a pipe on the bottom that feeds air from the front of the car. The lower part of the DoS intake should be connected there as well.
http://www.altaperformance.com/share...mpint400r2.pdf
Edit: It looks like on the bottom pipe you have to remove the stock elbow before you attach it to the intake.
PM me with your email and I'll get a set of the prospective buyer instructions off to you.
Have a good night.
-Clint
ebowling
90
Aug 4, 2019 09:15 AM
