R56 brake pad sensor
brake pad sensor
I just changed my front and rear pads
i hate those broken sensores for pad wear
so I spliced the wires together
now the abs light and and a couple of other warning lights are on.....
thoughts
please help
thoughts
please help
Thoughts? You did it wrong. You should have replaced the broken sensors with new unbroken ones. The computer doesn't like the wires spliced together. Or something just needs to be reset. Or you broke something else.
yep I think i did something wrong....
so
I will buy new sensors and installthem
I couldnt have damaged anything else
i tested what I was doing
when i snipped off the damaged sensors brake pad light remained on
when I wired them together allhellbroke loose onn the dummy lights
I will sepearate wires to see if I can tract a step back
and then order new sensors
any other ideas?
so
any other ideas?
Aug 25, 2015 09:18 AM
