R56 First time oil change by myself
Old May 6, 2009 | 12:30 PM
  #26
surfblue's Avatar
surfblue
It's easy, and it's fun
Originally Posted by fishbert
one reason I've never bothered to try an oil change myself is that it seems like a pain to dispose of the spent oil.
and with synthetics, do they need any special attention? or maybe it's easier to dispose of?
Changing your own oil is easy and fun. Just TAKE YOUR TIME and be methodical.
Here in NorCal, KRAGEN will take your used oil and filters. Call the store ahead to make sure they have room for BOTH oil and filter. Since Kragen is going to take your old oil, go buy one of those modern oil pans that will also hold and store your oil. That way you aren't having to pour oil from one container to another. It truly simplifies the task and the pan is pretty much a lifetime item.
If you don't have a Kragen, grab the phone book and call some local auto parts stores.
What works best for me, even with a low pan, is to run the driver's side of the car up on my LOW RAMPS, and the right side up on a couple pieces of 2x4, to give a little extra clearance. Make sure you get the pan set out far enough to the RIGHT because the oil is coming out to the side and will not being dropping straight down until it's a dribble.
Congratulations to all owners who undertake their own oil changes and then recycle properly!
Old May 6, 2009 | 02:07 PM
  #27
Robin Casady's Avatar
Robin Casady
In California, I believe the state provides oil containers.
http://www.ciwmb.ca.gov/USEDOIL/
All the auto supply stores in my area carry them, but are often out. Got one at Jiffy Lube (wouldn't go there for anything else ) when the stores were out.
We have WM for trash and recycling pickup. They will pick up used oil.
Old May 6, 2009 | 03:29 PM
  #28
Scoopmama's Avatar
Scoopmama
Robin~ Thanks for the info! We usually send our oil containers to the local high school auto class, and the teacher kindly accepts it. Now we won't have to bug him or haul it over.
Old May 6, 2009 | 05:52 PM
  #29
toolazyforalogin's Avatar
toolazyforalogin
Is there anything holding the oil filter in the housing or is it just an open/pull out/put new one back in process? (i.e. is it connected to the top somehow or is just sort of floating in there?) I have yet to tackle this but have all the tools lined up. Thanks.
Old May 6, 2009 | 08:10 PM
  #30
Robin Casady
Nothing holding it in.
Old May 6, 2009 | 09:28 PM
  #31
mellowmcs's Avatar
mellowmcs
there is sort of a tab that holds the filter to the top of the filter housing so they come out as one unit. however, it only takes a light tug to separate the two.
Old May 7, 2009 | 02:49 AM
  #32
toolazyforalogin
thanks!
Old May 7, 2009 | 01:17 PM
  #33
Oski's Avatar
Oski
Hi gababo,
Did you have much trouble with moving the coolant tank out of the way? Did the tank leak or spill at all? Did you have to completely remove the tank or did you simply move it out of the way?
BTW, is 5W-40 Mobil 1 synthetic oil MINI-approved? The auto parts store we were at didn't have any 5W-30 Castrol synth. We live in Northern California and the weather is mild right now, but gets hot in the summer.
Old May 7, 2009 | 02:51 PM
  #34
mellowmcs's Avatar
mellowmcs
Originally Posted by Oski
Hi gababo,
no leakage or spillage. you should not need to disconnect any of the hoses or open the tank. if you remove it from the mount (there is a tab on the bottom) it's much easier. You maybe able to do it without but you still need to reach down and remove the oil filter.
only mobil 1 approved by bmw/mini is 0W-40. this is the oil i use when i do the mid cycle change (1/2 before the oil service is due or every 7500miles)
Old May 8, 2009 | 01:41 PM
  #35
Oski's Avatar
Oski
Ooops, we did get Mobil 1 0W-40 (not 5W-40), so I think we're okay. Thanks for the reply.
Old May 10, 2009 | 01:25 PM
  #36
Robin Casady
Just noticed the Castrol Edge advertising banner here on NAM so I thought I'd check it out. I was disappointed.
After wading through their hype, I see that Castrol Edge 5W-30 has an ACEA A1 and A5 rating. Unfortunately, these are not as robust as the ACEA A3 rating recommended for MINIs in the UK owners manual.
The MINI (or BMW) branded 5W0-30 Castrol available at MINI & BMW dealers is rated A3. Mobil 1 0W-40 is also A3. Note that other grades of Mobil 1 do not meet this spec. Typically, the MINI branded 5W-30 is less expensive than Mobil 1. IIRC, I paid $5.40 per qt. at MINI of Mountain View, CA. I can't find any grade of Mobil 1 for that price in my area.
Old May 10, 2009 | 02:04 PM
  #37
koveras's Avatar
koveras
That's a very useful find. I never knew about the ACEA grades of oil. Thanks, Robin!
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
sprp85
Aug 22, 2015 06:16 AM
wind715
Aug 11, 2015 07:56 AM
ludedude
Aug 10, 2015 07:16 PM
