R56 Tested a CS and I have a question.
Old Jun 25, 2008 | 07:03 PM
FL MINI's Avatar
FL MINI
I drove an '08 CS today. In third gear (manual) when I would hit 6000RPM the engine would react almost as if it was upshifted. The sound change was VERY noticeable. It's a bit hard to explain. The salesmen noted it, but did not know what to say, or if it was normal. If I'm not mistaking redline is 6500 so it should not have been fuel cutoff.
Thanks all.
Old Jun 25, 2008 | 07:06 PM
lhoboy's Avatar
lhoboy
Thanks all.
Was it under full throttle. If so, the clutch might be slipping until you get to 6000 rpm when the torque tapers off.
Old Jun 25, 2008 | 07:17 PM
darmog's Avatar
darmog
Overboost function maybe?
Old Jun 25, 2008 | 07:35 PM
FL MINI's Avatar
FL MINI
Heavy on the gas, but not full throttle. The car had less than 100 miles so I would hope the clutch wasn't slipping. It didn't seem to be as we were accelerating right along with an increase in RPMs. I should have payed closer attention to see if the RPMs dropped when it happened. It was very odd.
Doc Pain
Mar 10, 2021 04:50 AM
jennster
Sep 28, 2015 06:19 PM
silence2-38554
Sep 28, 2015 12:19 PM
Sep 25, 2015 11:46 AM
Sep 25, 2015 11:44 AM
