bolt pattern and offset should be fine. however, the studs are thicker on the R56. 14mm vs 12mm I believe. so if you want the wheels to fit, you'll have to have someone bore out the holes to 14mm.
They will fit, no problem. R90s are available as an accessory for the R56, and it's not like any of the MINI wheels have/had bolt holes that are snug around the lugs, anyway.
Now Im confused. I was looking and R90s are not available for the R56. But I might be wrong Thanks
