R56 17" non-factory rims
Old May 8, 2008 | 12:33 PM
golden girl's Avatar
golden girl
I changed from 16" to 17" non-factory rims purchased from dealer and cannot get the shimmy out of my car at 55-65 mpr. Anyone had any problems like this, or do I have to re-purchase new factory rims?
Old May 8, 2008 | 12:34 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
My guess will be that you need hubcentric rings. What aftermarket wheels did you put on there? Did you install hubcentric rings to match the hub bore?
Either that or the tire company didn't properly balance the wheels when you had tires installed. The hub rings are more likely though.
Old May 8, 2008 | 01:07 PM
#20Works4me's Avatar
#20Works4me
Ditto on the hubcentric rings, 99% of after market rims have a large center bore to allow for a more universal fit for most cars within that particular bolt pattern application. Most wheel shops carry or can get the proper hubcentric rings for your Mini depending on the make and model of your new rim. The Mini hub diameter is 56.1mm so that should be the inside diameter (ID) of your hub ring and you will need the (OD) Outside diameter for the ring which will be the the center hub size of your new rim. A lot of aftermarket rims are 73mm but not all so don't quote me on that. Hope this helps good luck. Hey and post a pic of the rims on your car!
Old May 8, 2008 | 01:12 PM
Auto_Pilot's Avatar
Auto_Pilot
Also...did you transfer your TPMS? I'm wondering how you dealt with that.
Old May 8, 2008 | 03:26 PM
that7guy's Avatar
that7guy
Did you torque the wheels correctly?
Old May 8, 2008 | 05:37 PM
golden girl
yes, my husband made sure. He says the hub spacer for the rim is out of round
Old May 8, 2008 | 07:53 PM
Sin MINI's Avatar
Sin MINI
I had the same sympton...turned out both front tires/wheels were misbalanced. Bozos
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
luisfv56
Nov 16, 2015 01:55 PM
malibujoey
Nov 9, 2015 08:22 PM
Winston46
Nov 9, 2015 06:18 AM
