R56 Dogs?
Old Jan 22, 2008 | 02:28 PM
  #26
MINIdave's Avatar
MINIdave
Love the "Doggles"
Old Jan 22, 2008 | 02:29 PM
  #27
lotsie's Avatar
lotsie
Yup, all packed for a 1300 mile road trip. Even though her nickname is Black Lab Nav. unit, she tends to sleep most of the time
Mark
Old Jan 22, 2008 | 02:34 PM
  #28
lotsie's Avatar
lotsie
Here she is on the Dragon, you can just see her yellow Dragon slayer tag Yes she has a harness on.
Mark
Old Jan 22, 2008 | 02:46 PM
  #29
SomethingNew71's Avatar
SomethingNew71
I am a bit confused about which option in the drop down menu when purchasing the mat for the back of my car on poochstyle. I am wanting the mat that levels out the back and covers the seats and back when both the seats are down. I just don't know which one that is.
Old Jan 22, 2008 | 02:51 PM
  #30
WetNoseRanch's Avatar
WetNoseRanch
I must be nuts - I just ordered the Poochstyle bed and I won't even get the Mini for almost a month....
Of course our "Terrorist" Walter is used to cushy beds...
Old Jan 22, 2008 | 02:54 PM
  #31
hazmat's Avatar
hazmat
They are brand new and not on the web site yet! Contact Juliana at PoochStyle directly by email at sales@poochstyle.com and tell her you saw Echo's mat.
Old Jan 22, 2008 | 04:31 PM
  #32
dreman's Avatar
dreman
My MINI Doberman loves to ride in my MINI :D Like a match made in heaven.
Old Jan 22, 2008 | 04:41 PM
  #33
Robin Casady's Avatar
Robin Casady
Originally Posted by TheBigNewt
Dogs. I thought that's why they made pickup trucks. What else is that flat space back there good for?
Carrying hay bales. There is a great need for hay bales in suburbia and the inner city. That's why you see so many pickups in those areas.
Old Jan 22, 2008 | 04:48 PM
  #34
andyde's Avatar
andyde
priceless...
Old Jan 22, 2008 | 06:37 PM
  #35
hazmat's Avatar
hazmat
Nah........you would be nuts though if you didn't have a dog!
Old Jan 23, 2008 | 09:50 AM
  #36
RVExotics's Avatar
RVExotics
See, it's not the hair I worry about - and I have mini schnauzers so I wouldn't have to worry anyway. It's what the claws can do to the leatherette, door panelling, dash, etc!
But they want to ride soooooooo badly....
Old Jan 23, 2008 | 10:35 AM
  #37
MontanaMini's Avatar
MontanaMini
I have a Jack Russell Terror and a Golden Retriever...and I swear the interior of the MINI is a hair magnet. I also got the poochstyle cover for the back of my car, but the flat mattress slips towards the boot and I end up with hair along the top of the back of the seat....so now I'm thinking I should get the boot liner extension. Does anyone know if they've made '07 extensions yet? All I've seen is the 02-06 style.
Old Jan 23, 2008 | 10:51 AM
  #38
hazmat's Avatar
hazmat
Thats what I was afraid of too! This new model that I ordered actually secures to the top back front seat under the headrest and forms a gutter between the boot floor and the back of of the front seats. the hair seems to find its way to that spot naturally but with the piping along the edge, it pretty much stayed there. I had taken the pooch to a groomer a couple of days before the trip (one i hadn't used before) and they did a lousy job, loosening more hair than they actually removed so there was LOTS of loose hair on the trip. That gutter is nice detail but kind of an after thought since I was most interested in protecting the back of the front seats -- my dogs are leaners and true to form, he parked directly behind and against the seat for almost the entire trip. remarkably, he also stayed out of the front passenger seat at stops!
Old Jan 23, 2008 | 11:46 AM
  #39
TM3's Avatar
TM3
The poochstyle wasn't out yet when I bought my car, so I made up my own that handles hair, wetness and traction issues for our 2 - 80 Lb. mutts pretty well. Here's the basics:
1. Approx. 5' x 5' marine (rubber backed) carpet cut to cover the rear seat sidewalls and provide a barrier at the front seatbacks.
2. Approx. 6" thick block of foam to fill the boot area up to level with the folded rear seatbacks. I used 3 pieces of 2" foam board insulation cut to size and glued together into a single block.
3. A trip to the local auto upholstery shop to bind the edges of the carpet, attach nylon straps/quick connect clips for hanging the front off the headrest posts, and sew in velcro for fastening to the sidewalls and rear.
The project took only a couple of hours and came out pretty well, with a time and material cost of about $180. The finished piece can be installed or removed in a minute, which is good because it's much easier to pull it out and vacuum on a level floor than try to clean it in place. It contains all the dirt, water & hair, and doesn't move around at all with 8 scrabbling feet on it.
A couple of thumbnails are attached to get the idea, I don't seem to be able to upload full size photo's
Attached Thumbnails Dogs?-cargorug1.jpg   Dogs?-cargorug2.jpg   Dogs?-minipooches.jpg
Old Jan 23, 2008 | 11:59 AM
  #40
BlackdogTurbo's Avatar
BlackdogTurbo
seat belts
I agree on the 'no-loose-dogs-in-the-car' rule. It's dangerous for the driver, even if you don't like your dog much! Check out C.A.R.E. I think it stands for champion auto restraint equipment. Also "The Roadie" is quite good. I don't like the dinky things they have at petco. There's a reason *our* seatbelts are not made with cheap plastic buckles. If you have a big dog, you need a big harness. The CARE ones are made from stock seatbelt material, and heavy duty D-rings that clip into a strap which attaches to your seatbelt mechanism or tie-down rings. I sure wouldn't want a 70 lb projectile coming at me if I should get into an accident. Also - you may want to disable your passenger side airbag or put your dog in the back. I'm going to check out those links with seat cover info though. Labs have an absurd amount of shedding.
Blackdog
Old Jan 23, 2008 | 12:24 PM
  #41
MINIkitty's Avatar
MINIkitty
My dog Crash loves to ride with me. He's only 6.5 lbs and he rides in my lap or in the backseat or in his carseat when I have it hooked up. He learned to ride in my lap when he was a baby (before the mini) b/c my old car had absolutely no backseat so he had to sit in my lap or in his car seat and he really hates his car seat. I'm not so worried about hair b/c he doesn't shed, but I get the wonderful Nose Smears on all my windows. Even my house's windows have nose smears I just noticed the other day. Made me laugh pretty hard when I did notice.
I did notice he likes the back even more if the seats are folded down, probably b/c it raises him up high enough to be able to see out the windows then.
Old Jan 23, 2008 | 01:05 PM
  #42
WetNoseRanch
Juliana is great - I ordered "Echo's" pad yesterday and she offered great suggestions and handled the whole transactions promply though email. I sure the product is great - with customer service that good they must have the right attitude.
Of course they are dog lovers as well so what could be better?
-Kevin
Old Jan 23, 2008 | 01:08 PM
  #43
WetNoseRanch
Does anybody make a raccoon mat for the Mini?
Old Jan 23, 2008 | 07:08 PM
  #44
Littlesha's Avatar
Littlesha
Originally Posted by MINIdave
Just get a couple of these, no fur to clean up, you'll have plenty of room and they can "Spot" for you while you drive!
Ahhhh...another poodle person.
I have two....one of which is staring up at me as I type. As shed-free as you can get!
Now if I can find someone to create a sig of a black toy poodle in an Oxygen Blue /Black MINI!!!
Old Jan 23, 2008 | 09:02 PM
  #45
Charlie Croker's Avatar
Charlie Croker
I don't have any pictures, but I threw a cushion from a papazan chair in the back. It isn't a perfect fit, but it completely covers the rear area. It also provides a great cushion ride for my golden retriever. I also went down to the coast with my friend and her two dogs. A Yorkie-Poo and a Toy Poodle. The three dogs made nice in the back area along with luggage and food. Great trip!
Old Jan 24, 2008 | 04:51 AM
  #46
Littlesha's Avatar
Littlesha
Nah, you're not nuts at all. Us dog people more than understand and can appreciate that.
Sharon
Old Jan 24, 2008 | 06:19 AM
  #47
Lamcc83's Avatar
Lamcc83
A bulldog in a bulldog! :-)
Old Feb 4, 2008 | 02:11 PM
  #48
Striped Toad's Avatar
Striped Toad
Put the seats down yesterday, covered them completely with a blanket (incl. sides), somehow ended up with more hair inside the car than there is to begin with on our 15lb pug!
Old Feb 4, 2008 | 02:35 PM
  #49
oryx's Avatar
oryx
definitely going to have to get a doggie seatbelt harness for Pretzels. she is good about sitting the the seat while riding, but will stand up on the door when i get out of it and i just cringe to think how my piano black will look 1x after that....
Old Feb 4, 2008 | 03:28 PM
  #50
WetNoseRanch
Nice "doggles".
This may sounds weird but if the weather is not hot put a doggie jacket on Pretzels - the sweater type, it will "contain" most of the loose hair.
