R56 So do you all use Premium gas ALL the time?
Old Jan 19, 2008 | 05:11 PM
  #51
Maximusmini's Avatar
Maximusmini
I run 91-94 Octane. On a conservatively tuned Twincharged. I will never put in anything lower than 91. I also have used a few gallons of C-16 mixed with the premium fuel. I have no catalytic converter and I routinely check my spark plugs. Never had an issue.
Old Jan 19, 2008 | 05:15 PM
  #52
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by Littlesha
Cooper '08, and I live in South Florida.
If you had lived somewhere that actually has a winter season, you would be able to run a lower octane during that time because the air is cold enough to support it.
The Cooper has a pretty decent compression ratio, so I wouldn't run anything less than the mid grade where you live.
Are there any gas brands I should avoid...of the biggies?
And guys, thanks so much for all of the ultra-helpful responses!!!!!!!
If at all possible, you should run a Top Tier gas...
http://www.toptiergas.com/
Old Jan 19, 2008 | 06:38 PM
  #53
shokk's Avatar
shokk
7th Gear
Seriously, at a 10 cent difference, and filling maybe 10 gallons at a fill, it is the difference of $1. If you fill once ever 4 days, that's a difference of $91 over the year and $910 over 10 years (life of the vehicle?). I consider that cheap insurance.
Old Jan 19, 2008 | 06:41 PM
  #54
gokartride's Avatar
gokartride
Originally Posted by Crashton
Is the Prince the Peugeot, Citroen, BMW engine?
Old Jan 19, 2008 | 07:39 PM
  #55
Crashton's Avatar
Crashton
Originally Posted by jw34
Only gas with the highest ethanol content for me.
I'd be careful about that. There have been a few MINI owners who have had fuel system problems from using gas with too much ethanol in it. I suggest reading what the owners manual says is ok & sticking with that. I don't remember off hand how much ethanol is ok.
http://www.michiganmini.org/forum/in...p?topic=2945.0
Old Jan 19, 2008 | 07:55 PM
  #56
resmini's Avatar
resmini
My '03 Cooper seems to run a bit better on 89 octane mid-grade than on premium. Also, I see no reason why 87 octane would be a problem. If the mileage is lower, (and it may not be), it's likely to be less than the amount needed to make up for the cost difference between regular and premium.
Old Jan 19, 2008 | 08:35 PM
  #57
rattmobbins's Avatar
rattmobbins
All premium, all the time.
Old Jan 19, 2008 | 08:48 PM
  #58
Benibiker's Avatar
Benibiker
Is it worth saving 3 bucks per tank not to use premium? No...
Old Jan 19, 2008 | 08:50 PM
  #59
Montana82's Avatar
Montana82
I've found that when I use premium when it's crazy cold (30 and below) it starts really nasty(wanting to die at idle). But when I use a mid grade it's not affected by the cold. Anybody else have this issue?
Old Jan 19, 2008 | 09:38 PM
  #60
porkchop's Avatar
porkchop
My mini failed to start then did a nasty start during the seasons first cold snap. Then I had a bout of what sounded like engine knock at 10°F. Other than those two isolated instances, no real problems.
I run 93 year-round.
Old Jan 19, 2008 | 09:59 PM
  #61
resmini's Avatar
resmini
I think some of the octane enhancers they use can cause this, I've heard a few others talk about the same problem. Just because it cost more and they call it "premium" doesn't mean it's always better.
Old Jan 20, 2008 | 03:24 AM
  #62
glangford's Avatar
glangford
Yes, I have heard even Mini recommend the mid grade for cold seasons for people experiencing these cold start problems.
minicoclub
Nov 11, 2015 07:25 AM
minicoclub
Aug 25, 2015 09:07 AM
dchang0
Aug 10, 2015 03:37 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
