R56 Adjusting the Heated Seats Temperature?
Old Jan 14, 2008 | 11:24 PM
  #26
daffodildeb's Avatar
daffodildeb
Definitely 3 lights/first push on is the hottest.
Old Jan 15, 2008 | 04:46 AM
  #27
Minidrivr's Avatar
Minidrivr
Originally Posted by MiniSkim
They all feel really hot to me. I was suprised to see that the 3 light setting is actually the lowest. Doesnt seem to make sense but thats what Mini's own site says. Push once for warm, twice for toasty and 3 times for ahhhhhh. You would think that one light should be the lowest.
Originally Posted by mauberley
Indeed, and the owner's manual even says that "three LEDs indicate the highest temperature"... who's right? Only your butt can say for sure
This should be easy to confirm. Anyone with a IR temp gun?
Old Jan 15, 2008 | 05:07 AM
  #28
CR&PW&JB's Avatar
CR&PW&JB
Why the complaint in the first place ?! Nothing wrong with some free birth control... and much less painful than a vasectomy !
Old Jan 19, 2008 | 04:55 PM
  #29
JLLG's Avatar
JLLG
I recently had my driver's seat leather (back only) cover replaced and now the seat heater barely gets warm. The original seat cover and the current passenger seat warms very nice and hot (on the high leve). I actually like this because as someone else stated, I just turn it off typically after I am nice and warm. By the way, I was told that seat heating elements are integrated into the seat covers, seems ridiculous to me especially if we have to replace a heating element after warranty expires. The cost is probably 10 times more that it would need to be.
Anyway, I am puzzeled as to why my seat is now not warming as the original one did. The TSB only mentions 2 options, one for making hotter and one for making colder. This does not seem to provide much flexability for adjusting. Maybe its possible that the technician installed this part the wrong way? I want my seat back to the normal nice hotness Anyone have this too cold issue in the R56?
Old Jan 19, 2008 | 06:59 PM
  #30
Robin Casady's Avatar
Robin Casady
Better take it back. Sounds like the didn't do it quite right.
Old Jan 20, 2008 | 11:53 AM
  #31
JLLG's Avatar
JLLG
I definately will take it back but was just curious if any other R56 owners have had this problem?
I am theorizing 3 possible issues:
1. New seat cover with the heater has changed the resistance of the seat and will need adjusted (if possible).
2. The temp sensor is in the wrong place causing heater to power down too quickly.
3. Bad seat heater to being with.
Old Jan 21, 2008 | 06:27 AM
  #32
Halifax's Avatar
Halifax
Originally Posted by Bilbo-Baggins
They had a similar problem with the R50 and R53 cars and ended up with a fix that included the installation of a resistor in the seat heater circuit. If my memory serves me correctly.
But it wasn't until they had many complaints of "roasted nuts".
Sounds like birth control is a side benefit of the heated seats
On my MINI, there is a distinct difference between the settings, and I end up turning it off after running with setting 1 for a bit. The wife likes setting 3 ... we call it the "Princess" setting.
Old Jan 30, 2008 | 11:02 AM
  #33
sp_clark's Avatar
sp_clark
That CAN'T be right! 3 green on my seats makes me sweat unless the temp's near 0 F! Even then I can't leave it at 3G for too long... 2 is comfy below 40F, 1G hardly seems worth it.
This is on an early '07-build R56. 22,000+ US miles & still motoring!
Old Jan 30, 2008 | 11:17 AM
  #34
jw34's Avatar
jw34
Yeah that's goofy. 3 on mine is the hottest.
Old Jan 30, 2008 | 05:12 PM
  #35
Minidrivr's Avatar
Minidrivr
On the TV show "How it's made" a few days ago they showed the Mini's seats being built. The heating element is just a pad that is put on the seat cushion before the cover you see is attached. Interesting to see how the seats are made. Catch it on a rerun if you can. It was on Discovery or TLC type channel.
Like others have mentioned, any of the 3 settings is very hot...at first. After about 10 minutes the heat level tones down a bit. Before I realized that I was constantly turning them on and off. I've used all 3 settings now and I don't live near snow or sub-zero temps!
Old Jan 30, 2008 | 05:43 PM
  #36
jw34's Avatar
jw34
Hey cool, I watch that show sometimes. I've seen some weird things being made so the MINI seat would be a treat!
Old Jan 31, 2008 | 10:41 AM
  #37
Sithor's Avatar
Sithor
I've already found that the lowest setting is a bit too warm for me.
FrostyFox
Oct 28, 2015 02:06 PM
jziran
Aug 24, 2015 04:50 PM
bseiden
Aug 15, 2015 10:16 AM
ludedude
Aug 10, 2015 07:16 PM
marendt428
Aug 8, 2015 04:44 AM
