R56 Blue Fluid?
Old Dec 11, 2007 | 01:11 PM
Atlantis's Avatar
Atlantis
Blue Fluid?
My 2006 is leaking a blue fluid from the center of the engine area.
Old Dec 11, 2007 | 01:57 PM
Kasey's Avatar
Kasey
Judging from this thread:
https://www.northamericanmotoring.co...lue+oily+fluid
It is coolant, as long as you're sure it's not just washer fluid.
Sorry your MINI is sick!
Old Dec 11, 2007 | 01:59 PM
uzun's Avatar
uzun
It sounds like your coolant might be leaking. Have it looked at ASAP! If you have lost significant amount of coolant, your engine may overheat. Be careful!
Old Dec 11, 2007 | 02:11 PM
DPCooperS's Avatar
DPCooperS
My 05 had the same issue, found the leak comming from the Thermostat housing, fixed under warrantee. I've heard this is an issue on the 05's
Dave
Old Jan 11, 2008 | 09:45 AM
OldRick's Avatar
OldRick
Just had the thermostat housing replaced under warrantee. It leaked blue coolant fluid (doesn't evaporate like water) directly under the middle of the engine.
The SDA told me that they are replacing one or two of these per day, so aparently it's a widespread problem.
patsum
26
May 29, 2021 06:29 PM
pocketmaster
Sep 22, 2015 09:56 AM
Sep 18, 2015 02:44 PM
IFIXEM2
Sep 18, 2015 08:47 AM
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
