JBE LPFP Relay Substitute?
Subscribe
Sep 5, 2023 | 03:26 PM
I have the dreaded broken solder connection on my JBE LPFP relay 2011 Clubman S N18. Before I replace the relay (I'm going to be soldering anyway figured I'd replace the whole thing) what caused this in the first place?? Is this relay getting hot enough to melt that exact solder pin on all these JBE boards? My board appears to have a scorch mark under the relay! Should a higher amp relay be used? If so, is there one with the same pin pattern that someone has found?
Thank you again for all the assistance you ALL provide. Your collective knowledge and wisdom is very appreciated.
Reply 0
Subscribe
