R55 Heater blows cold, low coolant
Old Jan 28, 2020 | 05:32 PM
chrisbear's Avatar
chrisbear
Looking for some thoughts on where to start... I've researched this on the forums and have made a lot of headway, but am looking for additional opinions. 2012 Mini clubman S, 21k miles. I just bought it from the original owner who drove it sparingly. I've put about 1k miles on it in the last 30 days since purchase. While I was driving it last night, I noticed that the HEAT was blowing COLD (not hot). I about sh*t myself and my mind started percolating. It seemed to be worse at idle. So far, I've checked the coolant and it was about 24-36 oz low. I refilled it this morning. After refilling coolant, the problem resolved at higer RPMs but slightly persists at idle. (Coolant was checked ~45 days ago and was ok.) I ran diagnostics and it isn't throwing any codes.
Research on this forum has me concerned about water pump failure (which apparently has an open extended warranty on the issue (relatedly, there apparently was a class action against Mini for the water pump which resolved in a settlement)).
I have a scan guage 2 arriving tonight.
Anyone have any thoughts on the possible culprit or how to proceed? Clogged line? Leaky line? Leaky water pump? Something else?
Any feedback is appreciated!
Old Jan 29, 2020 | 05:35 AM
My guess is you have a leak, check these areas first. I would look for coolant leaks at the location of those parts.
https://www.northamericanmotoring.co...8-no-heat.html
On the thermostat you will need this part number for the newer MINIs. Look at your production date as you may also nee the harness adapter if its never been changed.
https://www.ecstuning.com/Mini-2012-...ng/Thermostat/
Old Jan 29, 2020 | 07:21 AM
chrisbear's Avatar
chrisbear
Thank you! I'll try to report back with my findings.
Old Jan 29, 2020 | 06:12 PM
Jason Cornelius's Avatar
Jason Cornelius
I had the same problem, my coolant reservoir was leaking like it separated in half. New reservoir and no issues since, obviously had a flush done and had them put the mini/bmw blue coolant back in.
dildo_swaggins
Apr 7, 2019 05:32 PM
oeklm
Nov 4, 2014 06:59 AM
kblydy
R55 :: Clubman Talk (2008+)
Apr 24, 2011 02:56 PM
Bmorezx3
Mar 3, 2011 01:46 PM
OldTimer
Dec 22, 2010 05:26 PM
