R55 DGI’s JCW R55 Ownership Log
Old Aug 19, 2018 | 05:32 PM
  #26
Gelmobile's Avatar
Gelmobile
Your alignment guy works on Sunday? :-)
Old Aug 19, 2018 | 06:00 PM
  #27
DGI's Avatar
DGI
These pics were from a couple days ago lol
Hes my best friend however and we've done plenty of wrenching on sundays...
Old Aug 20, 2018 | 04:39 PM
  #28
DGI's Avatar
DGI
Driving to work today the JCW temp gauge started creeping up while sitting in traffic. Reached ~103 degrees Celsius (~217 degrees F). As soon as I started moving it dropped back to its normal 90 degree C range.
Checked coolant after it was parked for a couple hours and it was fine. Did some errands on the way home (two hours of driving) and it was in the usual range as well.
Did an oil change when i got home using Mobil 1 5w-30 and a Mini filter just in case as I havent done one since taking delivery. Was going to wait until 15K miles as the dealer claimed they performed one prior to selling but figure 3K mile intervals would be safer anyway.
I'll keep an eye on it and see if the condition returns but otherwise, the Clubman has been alot of fun to drive!!!
Old Aug 20, 2018 | 05:01 PM
  #29
cristo's Avatar
cristo
Alliance Member
That doesn’t sound excessive.
The thermostat starts sending coolant to the radiator at about 90c.
The fan comes on at 108C and goes off at 105C.
Old Aug 20, 2018 | 05:14 PM
  #30
Gelmobile's Avatar
Gelmobile
Originally Posted by DGI
.Reached ~103 degrees Celsius (~217 degrees F). As soon as I started moving it dropped back to its normal 90 degree C range.
Funny, I brought my OBD to work to help with a coworker's car. On the way home, I got it hooked up just to check out the coolant temp for a 30 mins mix 80 and 65mph drive, it was hovering between 168 - about 189F or so (75-87C), with the ebay knocked off Forge. Read it on prior mod FAQ https://www.northamericanmotoring.co...fications.html from SSV that:
9) Upgraded Front Mount Intercooler (FMIC): This will provide slight HP gains with the stock engine, the main benefit is reducing the intake air temperature (IAT) so power can be maintained for extended periods. I have done enough datalogging both before and after installing my FMIC to show that the stock intercooler can not handle sustained periods of full throttle acceleration, IAT goes to 50C above ambient very quickly. But with an upgraded FMIC, it only goes up 9C (~50F). That means keeping the full engine power all the way down the straight when your foot is to the floor the whole time. Also this is important to support an ECU tune for increased performance. Installation is a bit more involved, but easily DIY
I think you re fine, considering you were in traffic...
Old Aug 20, 2018 | 05:18 PM
  #31
DGI's Avatar
DGI
I was only really concerned because Ive never seen the tempurature fluctuate that much (possibly never noticed).
i’ll get my scangauge mounted tomorrow to have a digital readout and keep a closer eye to see if it is indeed normal.
thanks for sharing the data bro!
Old Aug 20, 2018 | 05:32 PM
  #32
Gelmobile's Avatar
Gelmobile
sure, np, man, you won't see me remember useful stuff from work (or school) a few days ago, but fun stuff (my GF said useless info) like this, read once, almost never forget, selective memory rocks!
Old Aug 21, 2018 | 09:59 PM
  #33
squawSkiBum's Avatar
squawSkiBum
Moderator
That's describing the benefits of an upgraded intercooler for reducing Intake Air Temperature, not coolant temperature. The intercooler won't do anything for coolant temp, and the thermostat +radiator won't do anything for IAT.
Old Oct 21, 2018 | 03:07 AM
  #34
DGI's Avatar
DGI
R55 has been a dream come true so far. Its got utility, its economical and its fun!
impulsively gave it a new garage mate last week... we’ll see how this goes lol
Old Oct 24, 2018 | 07:17 PM
  #35
Gelmobile's Avatar
Gelmobile
Very clean looking C2, congrats! Before the Clubman, I was seriously lurking around two C4S on Rennlist marketplace. Ended up going the MC.
If IMS wasn't done, you may wanna look into that as a preventative measure before you need to open up the wallet, BIGTIME...my two cents.
Old Oct 25, 2018 | 02:25 AM
  #36
DGI's Avatar
DGI
Thanks! Ive wanted one for a while. The ‘99 with its Cable throttle always checked off an extra box for me.
Previous owner claims its been done about 2 years ago along with a new clutch. Clutch feels fine so im gonna see how it goes. Im going to catch up on other areas of maintenance that have been put off first and swap out the clutch possibly this summer :-)
Old Oct 25, 2018 | 05:02 AM
  #37
Gelmobile's Avatar
Gelmobile
I believe there is a serial number on the unit installed if he used the proper part from (LN).
https://lnengineering.com/products/ims-bearing-kits-for-porsche-m96-97-engines/ims-retrofit/dual-row-ims-retrofit-kit-for-my97-01.html
Old Nov 15, 2018 | 07:00 AM
  #38
DGI's Avatar
DGI
Small update!
almost due for another oil change. Car has been a fantastic daily driver constantly bringing back 30-32mpg. As such, my OBC computes estimated range to almost 500 miles to the tank!!!
Its snowing today so i’ll get to test out the all season tires on the way home :-) Very excited!
I also bought a Craven Speed short shifter from a member here. Perfect timing as my wife drove the car to Yoga last week and complained that the shifter was vague and mushy. Cant wait to get it installed!!!
Old Nov 20, 2018 | 09:50 AM
  #39
grunte's Avatar
grunte
I bought and installed that same short shifter from Waymotorworks. I'm very happy with it! I think you'll like it.
Mike
Old Nov 20, 2018 | 10:09 AM
  #40
DGI's Avatar
DGI
Looks like Cravenspeed came out with a new retaining system for the shifter... Will order it up when its time for the shifter to get installed. Was hoping to do it next week but i'm not sure how much time i'll have so I'll have to play it by ear.
Anyone know if the NM Shifter box upgrade is needed to get the full adjustable travel out of the Cravenspeed shifter?
Old Nov 26, 2018 | 06:32 AM
  #41
DGI's Avatar
DGI
Just ordered the Cravenspeed Shifter Bushing and NM Shifter Box from WayMotorWorks. Cant wait to get it all here and installed.
Going to keep my shift boot and OEM JCW **** for now. Couldnt justify dropping another $200 on the upgrades there but it all depends if I find myself constantly adjusting the shifter height or if it stays static...
Old Oct 29, 2019 | 03:03 AM
  #42
DGI's Avatar
DGI
39xxx miles and this little guy popped up
Old Nov 11, 2019 | 08:14 AM
  #43
DGI's Avatar
DGI
FCP Euro to the rescue!
Hawk HPS Pads and Zimmerman Rotors arrived the other day. Need to get the truck off the lift so I can get the Clubman up. Going to flush the brake fluid as well
Old Nov 12, 2019 | 08:41 AM
  #44
Kristof's Avatar
Kristof
Beautiful JCW Clubby Its sure is spec'd out perfectly.
Old Nov 13, 2019 | 12:19 PM
  #45
I really like that JCW Clubman, those seats are soo rare in that MINI
Old Nov 14, 2019 | 08:55 AM
  #46
DGI's Avatar
DGI
Thanks!!! I remember seeing a R55 with similar spec online in Florida about a year before I bought mine. I thought "thats so damn cool, doubt I'd ever see another one as cool as this one"
Glad I was able to snap it up when I found it! Originally mistook it for a GP when I saw it head on at the dealership lol
I still cant stop thinking how good GP wheels would look on this thing...
Old Dec 16, 2019 | 04:13 AM
  #47
Kupona's Avatar
Kupona
You will love the monster it becomes at stage 3. I may be biased as i went from S to stage 3 vs you going from Stage 2 to Stage 3. Love the tasteful mods you did. Very jealous of your rally lights, it is giving me the itch! Subscribed
Old Dec 23, 2019 | 05:02 AM
  #48
DGI's Avatar
DGI
Installed the Cravenspeed Shift Well and Shift **** the other day. **** didnt come with assembly instructions LOL so I had to do some googling but everything looks great.
Havent driven the car yet since I've done the brake job (want time to "Bed" the pads properly and work has been busy) bit I really like the way the ball shift **** feels in hand.
Should be able to install the modified Cravenspeed ScanGauge bracket by the end of the week and bring the car with me to work. Will be nice to finally monitor temps and pressures...
Old Jan 2, 2020 | 11:32 AM
  #49
DGI's Avatar
DGI
Finally got the Clubman’s brakes bedded properly and have been driving it two days now
New shifter setup rocks!!!
Old Jan 17, 2020 | 08:41 AM
  #50
dkdzyn's Avatar
dkdzyn
Did you put in that NM shifter box cover with the Cravenspeed short shifter arm? Does everything fit without modifications or is there any interference between the lower lid and the arm inside or the heat shield/exhaust outside? Thanks.
