R55 new HPFP.... can wont start
Old Nov 18, 2015 | 01:52 AM
roach_juts's Avatar
roach_juts
hello again
2009 clubman s apx 92000 miles
when the weather started to be come cold in Socal
my car is having a hard time to start, it just cranks but does not start
need to do the same process and wait for 5 mins for the engine to start running
just replaced the valve cover (indi mechanic) & and the HPFP was replaced by the Dealer.(11/06/15) because its covered by the 10yrs 100K warranty
but i am still having the same problems, CAR wont start, just crank, wait for 5 mins then the car starts,
tried the seafoam method & cleaned my plugs
Codes 2d6a, 2d6b, 2d68,2d69
Please Check the pics i got this codes and dont know what to do,
dont want to spend $$$ to the sealership!
Old Nov 18, 2015 | 01:03 PM
nkfry's Avatar
nkfry
If the car still has the same issues you took it to the dealer to fix, ie the HPFP then they should make good on completing the repair.
The fact that all 4 injectors are having a "high side circuit low" code is suspect.
What is your fuel rail pressure at startup and idle?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 18, 2015 | 01:53 PM
roach_juts's Avatar
roach_juts
i dont have the codes for the fuel rail pressure at start up, i just ask a favor from an indie shop to check my system, and the only codes he showed, i took a picture
ill try to get more codes.. thanks
and update you guys
the dealer wants me to pay 175.00 diagnosis fee,
since they did not make any $$$ when they replaced the HPFP, i did talk to the SA or
***-A regarding the same symptoms, he told me i have to bring it in & pay $$$
told him you guys should check the whole system, not just replacing the warrantied part....
Old Nov 21, 2015 | 11:29 PM
R*Clubby's Avatar
R*Clubby
The dealer does make money when they do the HPFP replacement: it is an emission replacement the MINIUSA pays them for. Warranty repairs are not a loss to the dealer, they do make money on them.
Establishing a good relationship with both a dealer and an indie gives you flexibility and choices. If the car ran "okay" before the pump replacement then the work done may have caused a new problem. Talk to your service advisor about that possibility that, if found to be their fault, there should be N/C
Old Nov 22, 2015 | 02:08 PM
roach_juts's Avatar
roach_juts
thanks for the reply
Old Nov 22, 2015 | 03:15 PM
fred340's Avatar
fred340
Can you get a reading from low pressure side, how much fuel pressure do you get in bar?
Do you get spark on the first cranks? Do the spark plug look soaked in fuel? Check your
AoxoMoxoA
19
Nov 5, 2015 01:30 PM
mdharman
R55 :: Clubman Talk (2008+)
Oct 12, 2015 06:37 PM
navybsn
Oct 4, 2015 03:27 PM
DTIREY
Sep 29, 2015 01:00 PM
