R55 Oil leak! Any ideas?
Old Oct 29, 2013 | 08:25 AM
Josh Rogers's Avatar
Josh Rogers
Ok so my cursed Mini has run into another problem. A couple of days ago there was a puddle of oil from under my car after driving it. At first I thought it was the oil pan from me hitting a divet in the road the day before. But I checked it and it was dry. Upon further inspection, the oil seems "clean" almost like brake fluid. Also the oil is all over the drive shaft and coming from somewhere above. I know its not a valve leak and I certainly hope it's not a head gasket. And like I said the oil seems clean. Any help would be greatly appreciated!
Old Oct 29, 2013 | 08:16 PM
OreoSAll4's Avatar
OreoSAll4
do you have pictures?
Old Oct 29, 2013 | 08:26 PM
cerenkov's Avatar
cerenkov
What side of the car is it on? Driver or passenger? or both?
Also you gotta give more info on your car. Year, make, etc.
Old Oct 30, 2013 | 04:27 AM
v10climber's Avatar
v10climber
Could also be transmission fluid. Perhaps a leaking axle seal? Fortunately it's a fairly easy replacement.
Old Oct 31, 2013 | 06:24 AM
Josh Rogers
I'll post pictures soon. It's an 08 clubman s with 67k. It's leaking on the driver side but can't find the exact spot. I always thought transmission fluid would be red, but that might not be the case for the minis.
Old Oct 31, 2013 | 06:51 AM
Josh Rogers
Pictures
Here's some pics. You can see in the first one in the upper left corner oil residue from what I believe to be the transmission cooler at the bottom but nothing at the top. Also in the second pic, you can see some residue in the bottom right. The oil is all over the axle and is coming from somewhere above it seems.
Attached Thumbnails Oil leak!  Any ideas?-imag0011.jpg   Oil leak!  Any ideas?-imag0012.jpg
Old Nov 6, 2013 | 11:29 AM
roach_juts's Avatar
roach_juts
Just got mine out from a mini dealer to have it diagnostic
I dont see any oil leaks, but the said i have to replace my Oil vacuum pump with will cost
850.00.. DAMN !!!
may be you have the same problem.... good luck
woodstudio
Mar 15, 2020 08:28 AM
ShadyCoop
Aug 24, 2015 06:05 AM
elightbo
Aug 17, 2015 01:50 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
