R55 will this fit?
will this fit?
I am looking to add turbo guage.
http://www.customcarscentral.com/ati...tm_medium=free
I see this and while it does not state R55 (2008-2010) I am wondering why it wouldn't..
Any thoughts are most appreciative.
Grady
Grady
It should fit. The R55 is identical to the R56 from the 'B pillars' forward.
You might also consider a gauge [package] supplied by Marshall. These seem to match the OEM gauge styling a bit better than that ATI offering; and being column-mounted, the Marshall gauges probably provide better visibility than one mounted inside a HVAC vent, no matter where you position your steering wheel. And ultimately, the gauge wiring is all going to lead to the same place -- which isn't going to be inside the HVAC vent...
thanks very much
That was my understanding about fitment as well.
I like those gauges you recommended. I am just having a hard time with the full kit $475 when the gauge I want is $94. The other gauges gve good info but admitedly the boost gauge is just for fun (most turbos have a gauge - heck a late 80's Pontiac Sunbird had one.
I may mount the Marshall gauge inside the vent
Thanks for your advice,
Grady
.Thanks for your advice,
Grady
Just curious, why not get the JCW gauges? you get to choose two of three different gauges (boost, temperature, and lateral G's) for $254 and its from MINI. That's in between the $94 and $475 listed above.
- You can get up to four gauges with the Marshall set; and
- The parameter selection (i.e., what can be presented on a gauge) is a bit wider, which allows me to have oil pressure and battery volts presented in my gauge cluster; to me, lateral G's are useless with regard to the operation of the vehicle
trw92a
Aug 26, 2015 01:47 PM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
