R55 Drivers side back up light... doesn't exist
Old Jul 31, 2008 | 07:53 PM
  #26
accordselux's Avatar
accordselux
Originally Posted by miniclubman
A single backup light mounted on only one side of the car is dumb, plain and simple. Backup lights are a safety feature. There should either be two, or a single center mounted light that casts a broad beam across the rear path of the car. As for a rear foglight, I had never even heard the term before owning my Clubman. It may be useful in some very specific weather conditions, but I'd certainly prefer two backup lights over one backup light and one rear fog light.
I don't know, I have my windows tinted as well, and I can see perfectly fine with the one reverse light! Looks odd, but I figure it was to make room for hte rear fog in other markets so I'm not complaining.
Old Oct 23, 2008 | 02:26 PM
  #27
OldLoad's Avatar
OldLoad
Let me ask this question. Can the front end of the rear fog light wiring harness can be connected to the same wires for the back-up light? If so, has anyone looked at making an aftermarket lens that would allow this light to pass through a clear lens? This should provide 2 back-up lights and an extra switch for the ejection seat (or any other desireable option)
Old Oct 24, 2008 | 10:01 AM
  #28
schatzy62's Avatar
schatzy62
This coudl easily be done by purchasing the left rear light fixture for a UK (England) car and then jsut running a wire from the passenger side to the drivers side of the US car and then you have two back up lights.
The part number would be 63.21.2.755.117 (white blinkers) or 63.21.2.755.115 (amber blinkers)
your local dealer can not order these but if you were to go on Mini2.com and check in with "chris at woodman bmw" then he could get you and ship you the part.
Old Oct 24, 2008 | 01:55 PM
  #29
hollyross's Avatar
hollyross
If you've ever driven at night on the Autobahn in the German countryside you'd have a better appreciation of that rear fog light...it saved my butt more than once (Europeans do not slow down in the fog). The one back-up light is perfectly adequate.
Old Oct 24, 2008 | 02:45 PM
  #30
timubik's Avatar
timubik
Rear Fog lights are required in most European countries. See the wikipedia article:
http://en.wikipedia.org/wiki/Automot...Rear_fog_lamps
Interesting notes:
- "If a single rear fog is fitted, most jurisdictions require it to be located at or to the driver's side of the vehicle's centerline"
- "To provide some safeguard against rear fog lamps' masking of brake lamps, ECE R48 requires a separation of at least 10 cm between the closest illuminated edges of any brake lamp and any rear fog lamp."
Old Oct 24, 2008 | 03:59 PM
  #31
portablevcb's Avatar
portablevcb
OK, just to recap.
The reverse light in the back, there is only one. Perfectly adequate.
The rear fog light is there for safety and is an option in the US. In many parts of the world it is required and is a nice touch to have if you've ever driven in dense fog.
There is provision for side park lights, also for other world consumption. Also very useful. If you have ever been down some sidestreets in Europe the only way you can tell a car is parked there is because of those little side lights. It's kinda like driving down a sidewalk with walls on both sides and no streetlights!
charlie
PS, I'm just happy that my wife lets me drive her Clubbie every now and then
Old Oct 24, 2008 | 08:36 PM
  #32
miniclubman's Avatar
miniclubman
I back down my driveway a lot more often than I drive on the Autobahn in heavy fog. Two rear backup lights make a lot more sense to me, and only one light on one side of the car is barely adequate, and a poor design. I understand why MINI sets it up the way they do, to save money and make the car easier to adapt to different markets, but it's certainly not the best solution from a safety standpoint.
Old Oct 24, 2008 | 08:55 PM
  #33
Benibiker's Avatar
Benibiker
The Scion xB also has one back-up light... Though it's much bigger than the Mini's...
Attached Thumbnails Drivers side back up light... doesn't exist-scion_xb.jpg
Old Oct 25, 2008 | 06:21 AM
  #34
OldLoad's Avatar
OldLoad
Schatzy62,
Got it; thanks. I am still in the UK and will take delivery of my US spec Clubman here for a short while before coming back to the US. Will get the appropriate parts here and make the fix when I am back there.
Old Oct 25, 2008 | 06:38 PM
  #35
maacodale's Avatar
maacodale
At 46 I guess I'm pretty old here. I can remember when cars didn't automatically have back up lights. Maybe that's why they called them the DARK ages. The only advantage I can see to having one backup light is you'll know when it's out much faster than if you have two.
Old Oct 25, 2008 | 06:59 PM
  #36
portablevcb
Naw, you're just a youngster
charlie (only 55)
Old Oct 26, 2008 | 05:02 AM
  #37
3DogDepot's Avatar
3DogDepot
The very first car I ever saw with only one back-up light was the 1929 Model "A" Ford my Dad owned and cherished as his "hobby" car. When he explained that it was all they had back then, and the rationale behind it, I remember thinking how odd it was, and I was glad we had evolved to today's symetrical use of two. Hmmm...seems like everything old is new again!
Old Oct 26, 2008 | 05:30 AM
  #38
tim781996's Avatar
tim781996
My 2004 MINI only has one reverse light. For those who need brighter lights, you can probably mount some bright lights to your bumper or roof, just like you see on plow trucks.
Old Oct 26, 2008 | 05:58 AM
  #39
lurch70's Avatar
lurch70
^ LOL
I don't think I ever used the backup lights as a guide for my own vision/view of the rear. I can't think of any car that I owned that had reverse lights bright enough for the task. But then again, here in NYC, its bright as day even at night
Old Oct 26, 2008 | 01:11 PM
  #40
portablevcb
I use the reflection of the backup light off the trees to tell me when I'm getting the the end of our driveway. The one light is plenty good for that. We don't have much light out here in the country where we live, unless there's a full moon. Then you just watch for little yellow eyes
charlie
surfblue
Oct 24, 2018 01:20 AM
maestro39
Oct 27, 2015 02:38 PM
cm.d
Aug 19, 2015 08:51 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
messyjesse96
Aug 12, 2015 05:51 AM
