R52 Harmonic Balancer
Old Jul 9, 2020 | 07:13 PM
BDCr52's Avatar
BDCr52
Harmonic Balancer
Found a good way to get a new harmonic balancer on the crankshaft. The engine mount bolts are the same pitch and thread as the harmonic bolt BUT longer. Use one of the mount bolts to get the balancer on to the crank. Reverse it out when an inch or so from the oil pump shield. Then finish it off with the regular harmonic bolt. Simple. Getting the old balancer off is easy with the r52 tool for around 50 bucks.
Old Jul 9, 2020 | 11:40 PM
OCR's Avatar
OCR
"Harmonic damper"
The damper does not "balance" anything in this engine.
It provides "only" a damping force of harmonic vibrations in the crankshaft. No balancing.
Just a heads up...for what it may be worth.
Mike
Old Jul 10, 2020 | 09:31 AM
BDCr52's Avatar
BDCr52
Originally Posted by OCR
"Harmonic damper"
Mike
Thanks for that clarification Mike. That makes more sense. Damper it is.
Old Jul 11, 2020 | 12:35 PM
BruceJ's Avatar
BruceJ
LOL, Thanks! I guess that explains why my new to me R53 came with that engine mount bolt still in. It also had the damper bolt attached to the engine mount.....
avinrulez
Sep 9, 2018 05:02 PM
bbarlow641
Sep 9, 2016 12:02 PM
mini22
Apr 6, 2014 01:34 PM
crammy
Jun 5, 2010 07:05 AM
kgardnez
Mar 31, 2008 03:21 AM
