R52 Best method to fix mushroomed strut towers?
So, I have the Cravenspeed reinforcing plates, but need to fix the mushroomed struct towers before they will bolt up. I know everyone says beat the towers back flat with a big hammer on a block of wood while the wheel is off the ground. But, to me, the strut bearing plate is still bent and will resist the attempt at straightening the strut tower. So, I am thinking that removing the strut, replacing the bearing is the way to go. While the strut is out, beat the tower flat.
This way, you are back to a straight bearing and flat strut tower before reinforcing with plates.
What do the masses say?
If you are going to go to the length of taking the strut off, I would get a couple of appropriate sized pieces of 1/4" plate steel, drill appropriate size holes in them to match the strut bolts and then use some grade 8 nuts and bolts to squeeze it back flat.
And installed Koni's to boot.
well, prevention is obviously the best measure. i was one of those obcessive zealots who put on the m7 strut tower plates and bar the first week i got the mini.
aside from prevention i would go camber plates and strut tower plates aka "the sandwhich" after straightening things out.....your method is certainly more civilized/well thought out. my next step was bc coilovers as i figured i'd be getting the plates and shocks...and would appreciate a little drop. still trying to slow down on those mods
good luck!
good luck!
so basically anyone who owns an R53 can become a victim of mushrooming?? I thought this was only a problem in the first run of R53 and that it was corrected somewhere near 04 or 05?? Am I wrong in this??? What about running stock suspension vs. lowering springs/shocks or coilovers does that add to it??
Steve
Steve
Steve
Steve
most have higher spring rates than stock. so the answer is.. maybe. Thread
wildwestrider
Dec 27, 2015 08:20 PM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
M7Speed
Sep 3, 2015 07:27 AM
Miami
20
Sep 1, 2015 07:20 AM
