R50/53 Exhaust Burble vs. MPG
Old Feb 16, 2007 | 05:14 PM
  #26
chows4us's Avatar
chows4us
Originally Posted by Dr Obnxs
But poor BMW/Mini, they had to have a memo on every SAs desk about the burble not being programmable into the older cars or being removable from newer ones. Now they'll have to have one labelled "Argh!" with the text, "can't you all make up your minds?"
Matt
I don't understand this. My 04 had NO burble whatsoever with the JCW exhaust. Way too quiet. Dump that, add the Borla Race ... all kinds of burble.
No software change
So what, exactly, was causing the exhaust burble in the Borla?
Old Feb 16, 2007 | 05:16 PM
  #27
chows4us's Avatar
chows4us
It serves no practical function at all in a modern fuel injected car, really. (This isn't exactly true, but close enough.....) That's why it's out one day, in the next and on and on....
If it serves no purpose, what does just a new catback create the burble with NO software changes?
I would add that this is also true on my Porsche. Adding a catback has created some burble where OEM it was quiet. Now this does include dropping the secondary cats.
There is something going on with the catback designs that is creating the burble ... maybe scavanging the gasses better?
Old Feb 16, 2007 | 05:21 PM
  #28
Pendergast's Avatar
Pendergast
I love the burble.
Old Feb 16, 2007 | 05:22 PM
  #29
Pendergast's Avatar
Pendergast
Love the burble.
Old Feb 16, 2007 | 06:35 PM
  #30
bamatt's Avatar
bamatt
Originally Posted by Pendergast
Love the burble.
Call Mini & tell them so they will bring it back
Old Feb 16, 2007 | 09:05 PM
  #31
minimarks's Avatar
minimarks
Originally Posted by rc'S
Yes, I like the sound, try to find more ways to make it do it!
I like the sound too, I'm why you would want to get rid of it... Maybe, just get a Prius?
Old Feb 17, 2007 | 01:48 AM
  #32
Deviant's Avatar
Deviant
MINI's do not "turn off the fuel injectors" upon deacceleration. They shorten the duration of the pulsewidth telling the injector to inject so as to allow a leaner A/F mixture but to compelely shut off the injectors while the engine is running and the ignition still firing is a great way to go too lean and break something. The burble is present in almost all cars if the right combination of exhaust tubing/muffling, A/F ratio, and ignition timing is present.
Old Feb 17, 2007 | 07:01 AM
  #33
jasonsmf's Avatar
jasonsmf
Originally Posted by Deviant
.... but to compelely shut off the injectors while the engine is running and the ignition still firing is a great way to go too lean and break something. ....
If you completely shut off the injectors you are not going to have ANY combustion, all you are doing is pumping air. This is in no way going to damage the engine.
Shortening the pulsewidth is how you will get lean combustion.
Either way, we are talking about decel here, when the engine is not on boost, and not under any load. Going lean under this condition is not dangerous like it is when you are under load.
Jason
Old Feb 17, 2007 | 07:09 AM
  #34
Dr Obnxs's Avatar
Dr Obnxs
THe injectors do shut off...
I"ve looked at the injector signal with an oscilloscope.
At the transition to lifting throttle, the ECU has to decide if your lifting or if your foot is just bouncing up and down a bit. That's why it doesn't shut the injectors off immideatly with a lifting throttle.
The change in burble with exhaust is just that, you're changing the muffleing and you hear things different (wait till you go with a header and get rid of the pre-cat!).
To make the burble or not is a question of injection and spark, and the threshold that's programmed for the ECU to interpret a lifting throttle as lifted vs bouncing. It's just software.
I can't speak to how Porsche does it, as I haven't logged the injector pulses.
Matt
Old Feb 17, 2007 | 07:40 AM
  #35
chows4us's Avatar
chows4us
Matt
Porsche does not burble OEM. Just changing the exhaust causes "some"
Same with the 04 MINI, changing to Borla created Burble where none existed before. So I got to figure the exhaust has "something" to do with it.
NO ECU changes to either car.
Old Feb 17, 2007 | 08:00 AM
  #36
erickvonzipper's Avatar
erickvonzipper
My Cooper, with the Megan Racing cat-back, produced just for us Cooper owners, =o) has a nice burble on trailing throttle. The higher you rev it and then let off, the better the burble. I _like_ it.
Zip
Old Feb 17, 2007 | 08:17 AM
  #37
Dr Obnxs's Avatar
Dr Obnxs
Drive a 75 caddy...
and the exhaust sounds like "woosh". Take off the mufflers, and it has all the fire and spit that any multi liter V8 ever had..... Changing exhaust doesn't cause it, it changes how it sounds when it comes out.
Matt
Old Feb 17, 2007 | 10:29 AM
  #38
erickvonzipper
Matt
Changing the exhaust changes how the sound comes out.
Zip
Old Feb 19, 2007 | 04:11 AM
  #39
rc'S's Avatar
rc'S
You've got me all wrong, I enjoy the "Burble". I'm the guy back in the 60's and 70's that had the glass packs and let'em rap. My friends new when I arrived!
Old Feb 19, 2007 | 07:37 AM
  #40
DixonL2's Avatar
DixonL2
glasspacks = mmmm
Old Feb 19, 2007 | 07:50 AM
  #41
Dr Obnxs's Avatar
Dr Obnxs
To be completely accurate...
Minis shut off thier fuel on engine braking EXCEPT when the car isn't up to operating temp, or if the RPMs are so low that the idle control circuit kicks in.
But like the poster above stated, for the most part, changing exhaust won't change what sounds the engine makes, just how you hear them.
Matt
CardinalsRule
Jun 11, 2016 04:34 PM
embiggenedmini
Oct 15, 2015 12:36 PM
Tribe
Sep 3, 2015 08:31 PM
buckeye_hunter
Sep 2, 2015 01:24 PM
Sep 2, 2015 09:05 AM
