R50/53 Clutch noise?
Old Mar 23, 2006 | 11:54 AM
  #26
mielnicki's Avatar
mielnicki
Originally Posted by cmyk
... since mini already released a TSB for it, just on the older models.
Right because the issue has been resolved on newer cars, with the new parts during build. At least in the eyes of MINI.
Steve
Old Mar 24, 2006 | 11:05 AM
  #27
brgfan's Avatar
brgfan
The '03, on which I originally experienced this problem, has been traded for an '05. The '05 exhibits the same type of noise as the '03 did before transmission replacement, but not nearly as loud.
On the '03 it really sounded like a top-end/dead lifter type of noise, but the only time I could hear it was with the clutch released in neutral.
On the '05, I hear the same noise, but I really have to listen for it. I haven't bothered to complain. It may be that a slight noise from the throw out bearing is normal.
When they replaced the transmission on my '03, I think it may have been because the noise was beyond normal.
Old Apr 27, 2006 | 09:10 PM
  #28
jazper11's Avatar
jazper11
OOh OOh can I join this clutch noise club, it seem like the cool thing to do.
My 06 MCS also makes this same exact noise
any one had any luck fixing this?
Old Apr 27, 2006 | 09:20 PM
  #29
Bakerman's Avatar
Bakerman
Originally Posted by YYC
The "what happens if you do nothing" question has not, to my knowledge (and I might have read every NAM and MINI2 post on this topic!!) been answered! Like you, I have had this since day 1, it is only noticeable if I engage clutch quickly while in neutral (so I let the pedal out slowly....and no tapping), and it is unchanged in 12 months of ownership.
I've had mine for a couple years and it's always done it now and then. I've done nothing to really fix it and currently have about 84k on the tach. No other problems so far with my trans. or clutch.
Old May 3, 2006 | 07:52 PM
  #30
mbutterf's Avatar
mbutterf
cmyk - I've have the same 06 astro black cs and I have the noise as well. My clutch sometimes feels tight as well. But not every time I engage it...its weird. Does anybody else have this problem as well
Old May 7, 2006 | 11:07 AM
  #31
promking's Avatar
promking
Just got mine and same thing. Searched and found no reasonable conclusion on a fix. Kinda dissheartening after spending 28K. Anybody out there with a fix?
Old May 7, 2006 | 08:09 PM
  #32
skillet's Avatar
skillet
You guys have nothing to worry about... it's normal. If you want to make it louder, throw in a lightened flywheel. :impatient Like someone had posted previously, let the clutch out slowly, and the noise gets softer. It's a normal sound. My VW Jetta (5 sp.) had the same noise before I put the lightened flywheel on. After the flywheel, it got extremely loud (a constant chatter, chatter, chatter.) I kept taking it back in to the dealer to get the problem fixed. After having the throwout bearing replaced (even though the clutch kit came with a new one), constant inspections, and major money dumped down the drain, we came to the conclusion along with researching that this was normal. Good luck, but don't let the sound bother you and ruin the fun of having one of the most fun cars on the road.
Old May 10, 2006 | 03:15 PM
  #33
paulo500's Avatar
paulo500
Yeah i was told by my mini service rep that the Getrag gearboxes ('04 and up i think) are 'noisy' gearboxes than the typical toyota or honda gearboxes. Infact he mentioned that the first mini's ('01-'03?) gearboxes are even noisier by comparison.
Old May 12, 2006 | 03:37 PM
  #34
gekko's Avatar
gekko
moi o si
mine does the same thing. only notice it when i fire it up cold in the gradge. don't notice it when i return and it's all warmed up. will do more research and see if anything comes up. about to crack 1k on the o.d.
any answer from those folks who had the tranny replaced? did it solve the noise?
Old May 12, 2006 | 04:14 PM
  #35
mitchman's Avatar
mitchman
The guy in the first post said that his only makes the noise when the clutch is out in neutral. This is a common problem with Miatas, maybe they are similar? Do the Mini's use a hydraulic clutch or a cable driven clutch?
The problem on the Miata was that the shaft that pushed against the clutch fork needed to have grease on the end of it. It was a really easy thing to fix.
This is my first post! (we don't even own a Mini.......yet!)
Old Oct 30, 2006 | 12:15 PM
  #36
FL_blue_MINI's Avatar
FL_blue_MINI
well im going to join this "club" too!!!! my car does the same thing. the only thing is that i only have 1,200 miles!!! i am going to go to the dealership this weekend. i hope its normal but we'll see.
Supertractor3
Apr 7, 2017 11:16 AM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Sc00terbum
Sep 11, 2015 07:17 AM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 02:06 PM
