R50/53 Front engine seal
Old Aug 14, 2006 | 03:04 PM
biz's Avatar
biz
Front engine seal
Can anyone tell me what exactly this is?
Old Aug 14, 2006 | 06:15 PM
biz's Avatar
biz
Anyone???? Anyone know????
Old Aug 14, 2006 | 06:30 PM
SRTech's Avatar
SRTech
It's the seal around the crankshaft as it exits the "front" of the engine. The harmonic balancer or accessory pulley is connected to the "front" end of the crankshaft.
Steve
Old Aug 14, 2006 | 06:37 PM
qwertmonkey's Avatar
qwertmonkey
That sounds right. When I googled it, it came up with crankshaft seals.
Old Aug 14, 2006 | 06:52 PM
k-huevo's Avatar
k-huevo
To add to what SRTech said, the front crankshaft seal goes around the crankshaft at the timing chain cover. It is a metal ring encased in rubber that prevents oil from escaping at the crank. It is fairly easy to access and is not hard to replace by the do-it-yourselfer although the tools are a bit pricy. If it is leaking a little around the outer diameter it won’t do any damage as long as engine oil is commensurately replaced. If the inner diameter of the seal is worn through to the metal, scoring of the crankshaft could occur so don’t take a chance, replace the seal if that’s why you are asking about it.
Old Aug 14, 2006 | 06:58 PM
SRTech's Avatar
SRTech
I wasn't sure he wanted to know that much so I gave him the short version.
Steve
Old Aug 14, 2006 | 11:16 PM
dix's Avatar
dix
Steve
That's funny! Here's a shorter version...I haven't a clue as to what either of you just say.
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
David.R53
Sep 1, 2015 06:49 PM
FLYM1N1
Aug 15, 2015 11:20 AM
