R50/53 Techniques for starting uphill with stick shift?
#26
Soon I will be starting to practice driving a manual while I wait for my MINI. I'll be practicing on my boyfriend's truck (he just doesn't know it yet!) and will be forced to learn how to start on inclines without the help of a handbrake because his truck has the kind of brake that you push down with your left foot! I'm certainly glad to read about everyone's techniques, and I think this will really help me out! Thanks!
#27
Once you've got the knack of it you can start on a very very steep hill with no ebrake and without much or any more slip than a stop on the level.
#29
thats how i do it on these organ pedal cars.
Originally Posted by mmatarella
I cover both the gas and brake with my right foot. I press the brake with the left side of my right foot and sorta roll my ankle to give her some gas. Then as I release the clutch I roll the right foot off the brake to gas only.
For some reason I find this easier than the classic heal and toe of left foot on clutch and brake. Maybe I'm just 'right footed'.
And of course as others have said practice is it. As it would happen I was just teaching a MINI owner with CVT how to drive stick Saturday. She did really well and we finished the day off with standing starts on a steep hill.
Seems like the 1/2 the trick is being able to engage the clutch quickly but smoothly. And likewise being able to move from the brake to the gas very quickly, but without over revving. The tendancy when learning is to hit the gas and rev pretty high. To move to the gas pedal very quickly and take it to say 2000 rpm but not over is a learned skill just like learning where the clutch engages.
#31
I'll...will be forced to learn how to start on inclines without the help of a handbrake because his truck has the kind of brake that you push down with your left foot!
#32
I grew up in the mountains of western NC, so I was forced to learn how to drive a stick on hills. It's nerve wracking when some jackhole gets right on your bumper on a steep hill, but you don't really need the e-brake -- it's mostly for sanity's sake, or if you're worried you don't have enough practice at it yet.
My biggest problem is just over-revving it. The closer the guy behind me is on my bumper, the more nervous I get and the higher I over-rev it. :-p
Of course, I've been living in good old flat Maryland for years, so I'd probably be tempted to use the e-brake method if I had another hill encounter with someone on my bumper now.
#33
Originally Posted by gokartride
Whoa, that does make it a bit more difficult, doesn't it!!! Practice on a smallish hill w/o traffic around, okay? And when you do get your MINI, don't hesitate to use the e-brake anyway. It's part of your equipment and there's no added points for not using it.
Originally Posted by acitydweller
the ebrake techniquie will save you in an uphill traffic situation, you know, the events that never happens until youre driving alone...
Thankfully there are plenty of practice hills near my house without too much traffic. I intend to take full advantage of them and try out some of the techniques mentioned here!
#34
I like to roll back a little, scares the crap out of the person behind me and they give me more room at the next light.
I have been driving a car with three pedals for years so I can hill hold, start from stop (with the roll back) and even have used the e brake, usually when there is a NYC taxi behind me. Yes there are hills in Manhattan, try 37th and 2nd ave frm the Queens mid town tunnel in rush hour.
#36
Originally Posted by ScottinBend
Parking brake is the best way. Just hold in the button as you are letting it out so you can synch it up with letting out the clutch.
#37
Having driven manuals most of my life, I very rarely used the e-brake method. Just hold the foot brake, let the clutch out until it starts to engage (and holds the vehicle in place at idle speed,) let foot of brake, depress accelerator and let off clutch. I find this doesn't that well with the MINI. It seems the torque, at lower rpms, just isn't enough and the engine rpms are slow to increase. Would have thought the "throttle by wire" made rpm increase faster, not slower. Anyone else had the same experience? Is there a ECU update that addresses this? Should note this is a "S." Does the supercharger have anything to do with it?
No doubt the heal to toe method works well but, I'm a old dog and use the e-brake method on the MINI. BTW, never use the clutch to "hold" yourself on a hill.
#38
Using the e-brake is really the best way, honestly. No roll back at all(especially important to the car behind you) and easy on the clutch. It does take practice though.
Parking brake method works on steep hills. Alternatively, find a steep driveway and during low-traffic hours practice for few minutes a day, for several days. This'll give you the confidence you need. Also try backing-up the hill. This is handy for parallel parking while the car is facing down-hill.
#39
Thanks everyone for the great replies
Thanks everyone for all the great insight on my uphill challenge.
Looks like the votes are about 60% for using the e-brake, 20% for the heel-toe method of using two feet to do the work of three 15% for riding the clutch so that first gear stays sort-of engaged, and two votes for red-line RPM and a quick clutch-release to ensure the engine doesn't die. I'll probably work with the e-brake for a while, then work on my foot-skills to see if any of the others are applicable to me.
I still giggle when I think of Kenshan's novel approach of resting against the car behind him to keep from rolling backward (tested by AntiqueCarNut).
Thanks again, --doug
#40
From Motoringfile.com "The 2007 MINI: In Detail": The Brake Assistant in the new MINI reliably detects application of the brakes in an emergency and builds up maximum brake pressure at the fastest conceivable rate. Yet another new function is Hill Assist uphill starting-off assistance combined with DSC, which activates the brakes when setting off on a gradient to prevent the car from rolling back.
Now why didn't they come up with this sooner??
#43
This was actually available on cars in the 30's. http://en.wikipedia.org/wiki/Hill-holder
#45
#46
What about while going uphill? How many RPMS do you leave it at? I constantly find myself shifting too early and then end up without enough power to speed up the hill and have to downshift again. I usually up shift a little over 3k rpm. I'm still in my break-in period so trying to stay below 4k as much as possible.
#48
Originally Posted by cold aspiration
What about while going uphill? How many RPMS do you leave it at? [Emphasis added.]I constantly find myself shifting too early and then end up without enough power to speed up the hill and have to downshift again. I usually up shift a little over 3k rpm. I'm still in my break-in period so trying to stay below 4k as much as possible.
#49
Subaru had the hill holder clutch in the '80's. I imagine that initially, MINI was a car for enthusiasts who just plain knew how to drive a stick. The "enthusiast" pool has dried up and now, in an effort to have broader appeal to the "stickless" (translate: clueless) generation, MINI now embraces the hill holder clutch. (flame on)
#50
I am one of the "clueless" generation you speak of, but I might add that the automatic revolution was not instigated by me, but rather by those before me, because by the time I learned to drive, no one I knew drove a manual. I always wanted to learn, but for lack of anything to learn on until now, I had to remain clueless. At least I am one of the few clueless ones out there who actually have always wanted to learn...and excuse me for not wanting to ruin my - or anyone else's - clutch whilst I attempt to overcome my clueless designation.
I just thought it was an interesting bit of trivia that many others on this forum who are actually trying to overcome their cluelessness might be interested in. No need to purposely insult those who are trying to actually elevate themselves closer to your level of righteousness, oh holy "enthusiast"
And for those of you nice enough to offer advice to us newbies, I thank you and of course, I will be practicing with the intent of making it perfect!
